10 Replies Latest reply on Oct 9, 2009 5:37 AM by Ned Murphy
    Incrimental zoom buttons (CS4)
    Gu55tav Level 1
      Im trying to script zoom in and out buttons in CS4 (Actionscript 2). I have the code sorted so they can be clicked once to zoom. I want to try and have 3 levels of zoom assigned to each button. Zo if pressing zoom up 1st press gives you 125% zoom, 2nd press 150% and 3rd press 200%. Same goes for the zoom out button but in reverse.
      The code im using for the buttons at present is...
      zoomupBtn.onRelease = function() {
      setProperty (_parent.pages, _xscale, "200");
      setProperty (_parent.pages, _yscale, "200");
      zoomdownBtn.onRelease = function() {
      setProperty (_parent.pages, _xscale, "100");
      setProperty (_parent.pages, _yscale, "100");
      What would i need to add to get this to ork.
      Any help is massivley appreciated.
        • 1. Re: Incrimental zoom buttons (CS4)
          Try:
               if(_parent.pages._xscale < 200){
                    _parent.pages._xscale += 50;
                     _parent.pages._yscale += 50;
               if(_parent.pages._xscale > 100){
                    _parent.pages._xscale -= 50;
                     _parent.pages._yscale -= 50;
          • 2. Re: Incrimental zoom buttons (CS4)
            Gu55tav Level 1
            Cheers for that mate.
            It coming back with some syntax errors but i'll have a play around with it to see if i can get it to work.
            • 3. Re: Incrimental zoom buttons (CS4)
              Gu55tav Level 1
              Ned,
              I was talking Rubbish. That works absolutely perfect!!
              You are a star!
              • 4. Re: Incrimental zoom buttons (CS4)
                Gu55tav Level 1
                Ned,
                Wonder if you know how i could solve this. Its the same item.
                Once zoomed the user can drag the pages around the screen but i defined bounderies so they couldnt drag past certain points. Now that i have more than one zoom level i think i need to repeat the drag script for each zoom level.
                Here is the script...
                pages.onMouseDown = function () {
                    // check if page is zoomed
                    if (pages._xscale != 100) {
                        Dragging = true;
                        updateCursor();
                        Mouse.hide();
                        dragCursor._visible=true;
                        startDrag(this,false, 1500,790,40,42);
                How would i go about this?
                • 5. Re: Incrimental zoom buttons (CS4)
                  You will want to make them relative to the _width and _height properties of the object being dragged, with consideration for the registration point of the object.
                  Just as an example, assuming the registration point is the top left corner:
                  left = left boundary
                  top = top boudary
                  right = right boundary minus this._width
                  bottom = bottom boundary minus this._height
                  startDrag(this, false, left, top, right, bottom);
                  • 6. Re: Incrimental zoom buttons (CS4)
                    Gu55tav Level 1
                    Hi Ned,
                    Im not sure if i worded the last question correctly.
                    Is there a way that i can set the startdrag properties for each level of zoom (i dont know if i can do this with one batch of code or wether i need to repeat the code posted previously for each variable of zoom) so that the user can only drag to a certain point around the screen on each zoom level.
                    The code i supplied works perfect at max zoom however when a lesser amount of zoom is applied they can drag past the limits that i would want them to.
                    I have tried repeating the code for each different zoom level however this doesnt seem to work.
                    Cheers
                    • 7. Re: Incrimental zoom buttons (CS4)
                      Gu55tav Level 1
                      More stuff....
                      I think im close to getting this to work however I cant get the code to differenciate between levels of zoom....
                      The code im using just now is:
                          if (pages._xscale != 25) {
                              Dragging = true;
                              updateCursor();
                              Mouse.hide();
                              startDrag(this,false, 950,490,600,322);
                              Dragging = true;
                              updateCursor();
                              Mouse.hide();
                      The values on the first part are correct for the 25% zoom as are the ones for 100%. When i run the movie it only uses the values in the second batch of code. How would I make it so it looks at the appropriate startdrag figures for each zoom level???
                      • 8. Re: Incrimental zoom buttons (CS4)
                        I'm pretty sure I understood what you want and that I offered an approach to solving it with one piece of code.  Your variables in the startDrag function would be using the current _width and_height properties to determine the boundaries.  If you couldn't understand that from my response, here is another attempt at writing it using some values... I don't know what your boundaries are, so assume tne normal boundaries are x = 100 to x = 300, and y = 100 to y = 400... and that the registreation point of the object is the upper left corner...
                        // startDrag(target, lock, left, top, right, bottom)
                        startDrag(this, false, 100, 100, 300-this._width, 400-this._height);
                        That line of code should apply to any scale because it uses the current width/height, so you don't need different sets of code for each size
                        • 9. Re: Incrimental zoom buttons (CS4)
                          Gu55tav Level 1
                          Hi Ned,
                          Sorry about that. Managed to get it to work.
                          Thanks again!!!
                          • 10. Re: Incrimental zoom buttons (CS4)
                            You're welcome
