0 Replies Latest reply on Oct 8, 2009 7:55 AM by davidhomer1978
    Flex and Restful Services
    davidhomer1978
      Hello,
      I'm new to the whole Flex system and I'm trying to integrate with WCF Rest Services
      I see that Flex doesn't support PUT and DELETE which is fine because we can use the x-http-method-override header which I assume you set in Flex with the headers property of the HttpService object?
      httpService.headers["x-http-method-override"] = "DELETE"
      The other thing is the HTTP Status code - it seems that Flex can't give you the HTTP Status code returned by the HttpService and that codes over 200 cause an exception. Is this correct and is this going to be resolved in Flex 4?
      Dave
