0 Replies Latest reply on Oct 9, 2009 3:26 AM by prajaktakenjale
    problem using XMLSocket. Sending data but not receiving Data
    prajaktakenjale
      I am using CS4 trial version. i am trying to use XMLSocket to talk to external world. I have written a server program in VC. Server creates a socket and does all other operations required for communication. In Flas CS4 I am using the sample program given. Which is as follows
      var theSocket:XMLSocket = new XMLSocket();
      theSocket.connect("127.0.0.1",55555)
      theSocket.onConnect = function(myStatus)
      if(myStatus)
      conn_txt.txt = "Connection Successful";
      else
      conn_txt.txt = "Connection Failure";
      function sendData()
      var myXML:XML = new XML();
      var mySend = myXML.createElement("the node");
      mySend.attributes.myData = "someData";
      myXML.appendChild(mySend);
      theSocket.send(myXML);
      // button sends data
      sendButton.onRelease = function()
      sendData();
      theSocket.onData = function(msg:String):Void
      trace(msg);
      the program is able to send data to the server but not able to receive data from server.
      in server program it is showing that data is sent successfully.
      Are there more settings required?
