2 Replies Latest reply on Oct 9, 2009 12:16 PM by Cr99
    Chart panel padding problem
    Cr99
      I have a custom component which is not displaying it's components correctly.  Here is the problem (the background color is there just to show the padding problems):
      Obviously the padding is larger on the left than the right, even though horizontalAlign is set to "center".  What is causing this?  Here is some sample code:
      <!-- Chart Panel -->
      <mx:Panel xmlns:mx="http://www.adobe.com/2006/mxml" styleName="panelfilled" roundedBottomCorners="true" horizontalAlign="center"
      paddingLeft="10" paddingRight="10" paddingBottom="10" paddingTop="35" resizeEffect="Resize" >
      <mx:Style>
      .panelfilled  {
                  border-style: solid;
                  border-thickness: 0;
                  border-skin: ClassReference("border.SimpleGradientBorder");
                  fill-colors: #FFFFFF, #FFFFFF;
                  corner-radius: 20;
      </mx:Style>
      </mx:Panel>
      // adding the chart to the panel via Actionscript snippets
      // here are the vertical axis objects (the horizontal axis is DateTimeAxis but is not shown here)
      var vAxis:LinearAxis = new LinearAxis();
      vAxis.baseAtZero = false;
      var axr:AxisRenderer = new AxisRenderer();
      axr.axis = vAxis;
      // flip left axis if location string is left
      if (location == "left") {
          axr.setStyle("verticalAxisTitleAlignment", "vertical");
      axr.placement = location;
      axr.setStyle("canDropLabels", "true");
      axr.setStyle("tickPlacement", "none");
      // genericChart is a CartesianChart
      genericChart.verticalAxisRenderers = renderers.toArray();
      genericChart.percentWidth = 90;
      genericChart.percentHeight = 100;
      genericChart.setStyle("fill", "#33cc33");
      genericChart.seriesFilters = [];
      chartPanel.horizontalScrollPolicy = "off";
      chartPanel.addChild(genericChart);
      // genericLegend is a Legend
      genericLegend.dataProvider = genericChart;
      genericLegend.direction = "horizontal";
      BindingUtils.bindProperty(genericLegend, "width", chartPanel, "width");
         genericLegend.setStyle("direction", "horizontal");
      chartPanel.addChild(genericLegend);
      // end code snippets
      The problem gets even worse when percent width is set to 100% as it completely clips off the chart:
