0 Replies Latest reply on Oct 9, 2009 11:15 AM by kevinklin
    [svn:fx-trunk] 10951: TitleWindow initial checkin.
    kevinklin Adobe Employee
      Revision: 10951
      Author:   klin@adobe.com
      Date:     2009-10-09 10:15:44 -0700 (Fri, 09 Oct 2009)
      Log Message:
      TitleWindow initial checkin. This is the spark equivalent of the mx:TitleWindow. One major difference is that we support a new skinstate called active. In this state, the titlebar of the window that is in focus or if one of that window's children is in focus.
      -Added TitleWindow component to spark framework.
      -Added new TitleWindowBoundsEvent to define events when you drag a TitleWindow.
      -Added TitleWindow default skin and wireframe skin.
      -Included TitleWindow to manifests and stylesheets.
      -Added TitleWindow checkin test.
      -Modified Panel's controlBarGroupProperties and related constants to be mx_internal in order for titlewindow to have the correct state when the controlBar is present and visible.
      -Added ASDoc example for TW.
      -Added icon for FB integration.
      -Changed mx:TitleWindow's Alternative metadata to point to the spark TitleWindow.
      SDK-23648 - small cosmetic fix on TitleWindow skin for titleDisplay overlapping with the closeButton
      QE notes: TitleWindow ready for testing.
      Doc notes: Yes
      Bugs: SDK-23648
      Reviewer: Ryan
      Tests run: checkintests
      Is noteworthy for integration: Yes
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23648
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/TitleWindow.as
          flex/sdk/trunk/frameworks/projects/spark/defaults-3.0.0.css
          flex/sdk/trunk/frameworks/projects/spark/defaults.css
          flex/sdk/trunk/frameworks/projects/spark/src/SparkClasses.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Panel.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/PanelSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/defaults.css
          flex/sdk/trunk/frameworks/projects/wireframe/src/WireframeClasses.as
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/PanelSkin.mxml
          flex/sdk/trunk/frameworks/spark-manifest.xml
          flex/sdk/trunk/frameworks/tests/basicTests/BasicTests-config.xml
          flex/sdk/trunk/frameworks/tests/basicTests/BasicTests.mxml
      Added Paths:
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components/examples/SimpleTitl eWindowExample.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components/examples/TitleWindo wApp.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/TitleWindow.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/TitleWindow.png
          flex/sdk/trunk/frameworks/projects/spark/src/spark/events/TitleWindowBoundsEvent.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/TitleWindowCloseButtonSkin .mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/TitleWindowSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/TitleWindowCloseBu ttonSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/TitleWindowSkin.mx ml
          flex/sdk/trunk/frameworks/tests/basicTests/spark/scripts/TitleWindowTestScript.mxml
          flex/sdk/trunk/frameworks/tests/basicTests/spark/views/TitleWindowTests.mxml
