0 Replies Latest reply on Oct 9, 2009 11:26 AM by LarrySpace
    2 strange issues for begginer in action script
    LarrySpace
      Hello… I am new to action script and I am (pretty) confused… so any help is valuable!!!
      --- issue 1 -----------------------------------------------------------------------------
      I have the follow code… and I get blank page… nothing is appeared on the stage at all!!! For god’s sake, what is wrong?
      package
        import flash.display.Sprite;
        import mx.core.ButtonAsset;
        public class ASProject2 extends Sprite
          public function ASProject2()
            var mb: ButtonAsset = new ButtonAsset();
              mb.x=100; mb.y=100; mb.width=200;
              addChild(mb);
      --- issue 2 -----------------------------------------------------------------------------
      Which button is the more simple button to use?
      I found the spark components button is the component that Flash Builder uses if you write in mxml language. So I add the folder to my project’s libraries paths, in precise I added as SWC folder the follow folder:
          c:\Program Files\Adobe\Flash Builder Beta\sdks\4.0.0\frameworks\projects\flex4\src\spark\components\
      Here is the (very simple) code (with compiler’s errors):
      package
        import spark.components.Button;  // <- compile time error: 1172: Definition spark.components:Button could not be found.
        public class ASProjectInFB4 extends Sprite
          public function ASProjectInFB4()
            var ab : Button = new Button(); // <- compile time error: 1046: Type was not found or was not a compile-time constant: Button.
              ab.x=10;
              ab.y=10;
              ab.width=200;
              ab.height=100;
              ab.enabled=true;
            addChild(ab);
      The problem (as you see) are the two compiler errors. Now… if get the cursor on “Button” text in my code and I press the F3 the Flash Builder transfers me to the declaration of Button class in the proper Button.as file! So I suppose that my definition in my preceding code is correct. If I remove the the SWC folder from the libraries of my project, the F3 buttons doesn’t transfer me anywhere, so the SWC folder definition is working too…
      What is wrong?
      Regards
