0 Replies Latest reply on Oct 9, 2009 12:34 PM by Jason Szeto
    [svn:fx-trunk] 10955: ComboBox initial checkin
    Jason Szeto Level 3
      Revision: 10955
      Author:   jszeto@adobe.com
      Date:     2009-10-09 12:34:12 -0700 (Fri, 09 Oct 2009)
      Log Message:
      The ComboBox component is similar to a DropDownList but has a TextInput instead of a Label. A user can type into the TextInput and the dropDown will scroll to and highlight the closest match.
      Users are allowed to type in an item not found in the dataProvider. With this behavior, a ComboBox acts as a list of suggested values, while a DropDownList acts as a list of possible values.
      The full spec is located here:
      http://opensource.adobe.com/wiki/display/flexsdk/Spark+ComboBox
      This checkin includes the following:
      - All public APIs implemented
      - All styles implemented (except for cornerRadius)
      - Basic keyboard and mouse interaction working
      - Spark and Wireframe skins implemented
      - Added custom selectedItem support to ListBase
      What is missing:
      - The keyboard and mouse interactions are partially implemented.
      - The TextInput caret and selection behaviors are not implemented
      - The changing event is not cancellable if setting a custom selected item
      - Need to refactor DropDownList into DropDownList and DropDownListBase
      QE notes: None
      Doc notes: None
      Bugs: None
      Reviewer: Glenn
      Tests run: List, DropDownList
      Is noteworthy for integration: No
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/defaults.css
          flex/sdk/trunk/frameworks/projects/spark/src/SparkClasses.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/DropDownList.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/List.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/SkinnableDataContainer.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/ListBase.as
          flex/sdk/trunk/frameworks/projects/wireframe/defaults.css
          flex/sdk/trunk/frameworks/projects/wireframe/src/WireframeClasses.as
          flex/sdk/trunk/frameworks/spark-manifest.xml
      Added Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/ComboBox.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ComboBoxButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ComboBoxSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ComboBoxTextInputSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ComboBoxButtonSkin .mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ComboBoxSkin.mxml
