0 Replies Latest reply on Oct 9, 2009 1:56 PM by Chet Haase
    [svn:fx-trunk] 10960: Fixed performance of Wipe effect.
    Chet Haase Level 3
      Revision: 10960
      Author:   chaase@adobe.com
      Date:     2009-10-09 13:55:47 -0700 (Fri, 09 Oct 2009)
      Log Message:
      Fixed performance of Wipe effect. It turns out that micro-tuning the shader code is very important, since that same inner loop runs on every pixel of the bitmap being affected. This change splits the single Wipe shader (with a direction parameter) into four separate Wipe shaders (WipeLeft, etc.), to avoid a switch on the direction parameter. Also, it avoids some setup of pixel values, only bothering to sample the pixel values after it determines which image to sample from. Little stuff, but gained about 20-25% performance on some sample wipe effects.
      QE notes: This broke 3 Wipe effects tests because the old WipeEffectInstance class went away. These tests have supposedly been updated by the time this checkin is happening.
      Doc notes: No
      Bugs: sdk-23279
      Reviewer: Corey
      Tests run: checkintests, mustella spark/effects
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/sdk-23279
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Wipe.as
      Added Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/WipeDown.pbj
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/WipeDown.pbk
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/WipeLeft.pbj
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/WipeLeft.pbk
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/WipeRight.pbj
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/WipeRight.pbk
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/WipeUp.pbj
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/WipeUp.pbk
      Removed Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Wipe.pbj
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Wipe.pbk
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/supportClasses/WipeInstance.as
