0 Replies Latest reply on Oct 9, 2009 2:55 PM by Chet Haase
    [svn:fx-trunk] 10961: Fix for occasional RTE in transform effects.
    Chet Haase Level 3
      Revision: 10961
      Author:   chaase@adobe.com
      Date:     2009-10-09 14:55:11 -0700 (Fri, 09 Oct 2009)
      Log Message:
      Fix for occasional RTE in transform effects. The problem was that an object whose parent container was 3D transformed which then underwent a 2D transform effect might try to access the 2D matrix of the display object. In some situations, that 2D matrix is null, because the 3D matrix on the display object is the one currently being used.
      The fix is to allocate AdvancedLayoutFeatures and let that class handle this matrix abstraction for us.
      QE notes: None
      Doc notes: No
      Bugs: sdk-23546
      Reviewer: Evtim
      Tests run: checkintests, mustella spark/effects
      Is noteworthy for integration: Yes
      Ticket Links:
          http://bugs.adobe.com/jira/browse/sdk-23546
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/flash-integration/src/mx/flash/UIMovieClip.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/core/SpriteVisualElement.as
