3 Replies Latest reply on Nov 2, 2009 2:51 AM by Rodrigues Regan
    HDV and AVCHD video is upper field first?
    ruzun Level 1
      Using the Mercalli Plugin under PE8, I now have to manually choose the field order for my clips.  Under PE7 it would give me an AUTO option, but that seems gone under PE8.
      I use 2 camcorders, one is an HDV format 1080/60i Sony HDR-HC7, the other an AVCHD 1080/60i format Sony HDR-XR520V.  Are both of these Upper Field First format camcorders?
      It offers Upper Field first and HDV upper field first as options.  Is there any difference?  would AVCHD be considered HDV for these purposes?  I'm trying to find the correct setting for the video format tab of my clips under PE8, and am unsure which Mercalli option is the correct one.
      -Roger Uzun
        • 1. Re: HDV and AVCHD video is upper field first?
          A.T. Romano Level 7
          runzun
          HDV and AVCHD camcorders have Upper Field First.
          The tricky part is when you confuse SD with DV. DV has Lower Field First. But not all SD is Lower Field First and can be Upper Field First.
          So, at this time, I am not sure if Mercalli is grouping HDV and AVCHD under the "HDV Upper Field First" and considering "just Upper Field First" to be related to the non DV SD which has Upper Field First.
          I am trying to research that now.
          ATR
          • 2. Re: HDV and AVCHD video is upper field first?
            A.T. Romano Level 7
            http://www.prodad.de/faq/01/gb/faq-00000072-00000006.html
            This is the closest that I came to a ProDad refinement of that video format setting in Mercalli.
            For HDV (1440 x 1080), HDV Upper Field First is straight forward.
            For DV, Lower Field First would is straight forward.
            For SD (non DV), can be Upper Field First, so it would seem appropriate to use Upper Field First.
            But, we know that AVCHD is Upper Field First, 1920 x 1080, and technically not HDV. But, the question pops up where to class AVCHD, under HDV Upper Field First or just Upper Field First ProDad Video Format choices. At this point, I would look at it under the HDV Upper Field First and leave Upper Field First for the SD (non DV).
            But read the above link and what it seems to be saying about the use of the video format setting in Mercalli.
            ATR
            • 3. Re: HDV and AVCHD video is upper field first?
              Rodrigues Regan
              As per my experience with camera's, mostly all Hard disc based camera's are Upper Field first while Tape based camera's happen to be lower field first.
