2 Replies Latest reply on Sep 5, 2008 11:26 AM by maxndex
    Error #1096 while doing HTTPRequest (AIR)
    SA_TPS
      I'm having troubles with a [RPC Fault faultString="Error #1096: XML parser failure] error when I try to run a HTTPService. The following is my code. It only happens when I do my http.send function. Any ideas? I have another application that I used the same code on and it worked fine.
      <mx:WindowedApplication xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute" backgroundGradientAlphas="[1.0, 1.0]" backgroundGradientColors="[#FFFFFF, #FFFFFF]" width="369" height="234" title="SMF: Product and NewSku Deletition Tool">
      <mx:Script>
      <![CDATA[
      import mx.controls.Alert;
      import mx.events.CloseEvent;
      private var params:Object = new Object();
      public var reasons:String = new String();
      public var ids:String = new String();
      public function deleteProduct():void
      var a:Alert = Alert.show("Are you sure you want to\ndelete Product or NewSku: (" + prodID.text + ") ?","Confirmation", Alert.YES|Alert.NO,this,confirmHandler);
      public function confirmHandler(event:CloseEvent):void
      if (event.detail == Alert.YES)
      deleteProducts.method = "POST";
      reasons = reason.text;
      ids = prodID.text;
      params = { "id": ids, "reason": reasons };
      deleteProducts.send(params);
      else if (event.detail == Alert.NO)
      </mx:Script>
      <mx:HTTPService url=" http://addressToWhereASPPageIsThatRunsTheDeleteFunctionFromTheDatabase.asp" id="deleteProducts"/>
      <mx:Label x="10" y="27" text="Product ID or NewSku:"/>
      <mx:Label x="10" y="53" text="Reason:" />
      <mx:TextInput id="reason" x="10" y="79" width="347" height="73"/>
      <mx:Button x="130" y="160" label="Delete Record" click="{deleteProduct();}"/>
      <mx:TextInput x="147" y="25" width="210" id="prodID"/>
      </mx:WindowedApplication>
      Now, when ran, the application does not lose functionality (i.e. it still deletes the record and shoots the email out) when it shoots out the error.
      Help Please!
      Luke
