0 Replies Latest reply on Oct 10, 2009 2:29 AM by cosmits
    Flex 3 - CF9 filereference.upload test
    cosmits Level 1
      Hi
      i run a filereference.upload test flex application which uploads a file through a coldfusion server.
      i’m using flex 3 and coldfusion 9.
      i’m also passing parameters in the URLRequest that points to the upload cfm file.
      when i run my test using the built-in web server (Jrun) all seems to work just fine
      when i run the same test on a coldfusion instance that runs on Apache web server, it throws a I/O Error…
      i suspect i’m missing some kind of a configuration i need to perform when moving to a production setup rather then a development environment…
      can anyone guide me through this?
      does it have to do with security? on the client? on the server?
      i’m still running on localhost…
      summery...
      attached are the mxml file and the cfm file
      works great on built-in server
      throws a I/O error when runs through Apache
      cheers
