8 Replies Latest reply: Oct 15, 2009 2:07 AM by Kristtee RSS
    as3 xml trouble
    Kristtee Community Member
      hi there
      as a newbee...it is not easy at all. somehow i manage to put together my app. but in the end - jezzz what a troubles. take a look and help me please.
      i want the data from xml to load.
      thanks in advance
      krs
        • 1. Re: as3 xml trouble
          CaioToOn! Community Member
          Hi, Kristee.
          There is three mistake:
               1st) You're duplicating the "loader" and "request" variables at
          // load text
          var loader:URLLoader = new URLLoader();
          var request:URLRequest = new URLRequest("lorem.txt");
          loader.load(request);
          loader.addEventListener(Event.COMPLETE, loadcomplete);
          function loadcomplete(event:Event) {
              // move loaded text to text field
              myTxt.text = loader.data;
              // Set myTxt as target for scroll bar.
              mySb.scrollTarget = myTxt;
             You need a different variable name, so, change it to "textLoader" and "textRequest", for example, in all the 6 occurrences.
               2nd) The correct variable name is "dataXML", not "teamXML".
           var myDP:DataProvider = new DataProvider(teamXML);
               3rd) In your XML, when closing the root node <data>, you misstyped it to </date>.
          I hope this help.
          Regards,
          CaioToOn!
          • 2. Re: as3 xml trouble
            Hi
            Thank you - CaioToOn. You are The Man. As you have helped me, i did all the corrections and it is just cool. There  is one more question. I wonder whether it is possible to bind the image and textfield data from the same xml file. Presently it is not from the xml data. Can you guide me through..Please. Please.
            I really appreciate your time. Thank you again.
            regards
            Kristtee
            • 3. Re: as3 xml trouble
              Saransoft84 Community Member
              Try this code:
              The data from img and the desc from the XML
              var img_name:Array = new Array();
              var desc:Array = new Array();
              for (var i1:int=0; i1<dataXML.item.length(); i1++) {
              img_name.push(dataXML.item.img[i1]);
              desc.push(dataXML.item.desc[i1]);
              trace(img_name+":img_name");
              trace(desc+":desc");
              Saransoft
              • 4. Re: as3 xml trouble
                hello Saransoft
                first of all i thank you so much. yet as i am too new to this..i try to use the code you have given me. but since i did not know how to use - where to put it, i have messed the whole thing up. truly sorry. can you help me please.
                Thank you
                kristttee
                • 5. Re: as3 xml trouble
                  Hi Kristtee,
                  It simple ya.
                  Here is code:
                  import fl.containers.UILoader;
                  import flash.net.*;
                  import fl.controls.UIScrollBar;
                  import flash.events.*;
                  import fl.controls.dataGridClasses.DataGridColumn;
                  import fl.data.DataProvider;
                  var request:URLRequest = new URLRequest("datas.xml");
                  loader.addEventListener(Event.COMPLETE, loaderCompleteHandler);
                  function loaderCompleteHandler(event:Event):void {
                  var dataXML:XML = new XML(loader.data);
                  var nameCol:DataGridColumn = new DataGridColumn("cate");
                  nameCol.headerText = "cztegory";
                  nameCol.width = 180;
                  var avgCol:DataGridColumn = new DataGridColumn("txt");
                  avgCol.headerText = "Head Line";
                  avgCol.width = 400;
                  var myDP:DataProvider = new DataProvider(dataXML);
                  aDg.columns = [nameCol, avgCol];
                  aDg.width = 580;
                  aDg.height = 180;
                  aDg.dataProvider = myDP;
                  //aDg.rowCount = aDg.length;
                  var myTxt:TextField = new TextField();
                  myTxt.border = true;
                  myTxt.defaultTextFormat;
                  myTxt.wordWrap = true;
                  myTxt.width = 235;
                  myTxt.height = 150;
                  myTxt.x = 340;
                  myTxt.y = 10;
                  var mySb:UIScrollBar = new UIScrollBar();
                  mySb.direction = "vertical";
                  // Size it to match the text field.
                  mySb.setSize(myTxt.width, myTxt.height);
                  // Move it immediately below the text field.
                  //mySb.move(myTxt.x, myTxt.height + myTxt.x);
                  mySb.move(myTxt.width + myTxt.x, myTxt.y);
                  // put them on the Stage
                  addChild(myTxt);
                  addChild(mySb);
                  // load text
                  /*var txtloader:URLLoader = new URLLoader();
                  var txtrequest:URLRequest = new URLRequest("lorem.txt");
                  txtloader.load(txtrequest);
                  txtloader.addEventListener(Event.COMPLETE, loadcomplete);
                  myTxt.text = txtloader.data;
                  myTxt.text = desc[0];
                  var aLoader:UILoader = new UILoader();
                  aLoader.scaleContent = false;
                  aLoader.x = 10;
                  aLoader.y = 10;
                  aLoader.width = 320;
                  aLoader.height = 150;
                  aLoader.source = img_name[0];//"images/flower.jpg";
                  addChild(aLoader);
                  aLoader.addEventListener(Event.COMPLETE, competeHandler);
                  function competeHandler(event:Event) {
                  trace("Bites loader: " + aLoader.bytesLoaded);
                  Copy all this code and paste in urs
                  Saransoft
                  • 6. Re: as3 xml trouble
                    hello Saransoft
                    thank you so much. I did as you have suggested. coppied all the code replacing my messed up ones. then i test it. woops..the image and textfield data just stays the same. when i try to selected different item from the datagrid, the image and the data do not change. what i try to do is to build similar to Spry Products Demo. Sure it must be too easy for you. Please help me.
                    Thank you
                    regards
                    Kristtee
                    • 7. Re: as3 xml trouble
                      Just change the array value from both image and text when u click on the datagrid.
                      If u click the first data in the datagrid mean u pass the array value to 0.
                      aLoader.x = 10;
                      aLoader.y = 10;
                      if u click the second one the pass the value to 1
                      myTxt.text = desc[1]
                      aLoader.x = 10;
                      aLoader.y = 10;
                      aLoader.source = img_name[1]
                      Like wise the others
                      Saransoft
                      • 8. Re: as3 xml trouble
                        sorry it does not do anything. just the same.
