4 Replies Latest reply on Oct 17, 2009 2:38 PM by Evgeniy_M
    [not solved] The "change" event of a slider is fired on creation. How to modify this?
    vpxav
      Hello,
      I placed a HSlider inside a repeater.
      Here's my HSlider:
      <mx:HSlider id="desiredHumiditySlider"
           width="100%"
           minimum="0"
           maximum="100"
           dataTipPlacement="bottom"
           labels="['0%','50%','100%']"
           snapInterval="1"
           tickInterval="25"
           liveDragging="false"
           allowTrackClick="true"
           value="{infosRepeater.currentItem.@act_value}"
           change="sliderChanged(event);"
      My problem is that the sliderChanged function is called not only when I moved the slider's cursor, but also when the page is created.
      How to change this?
      Thanks a lot
        • 1. Re: [not solved] The "change" event of a slider is fired on creation. How to modify this?
          Evgeniy_M
          Hello,
          In my test, the slider does not send the change event on creation. Here is my code.
          <mx:Application
               xmlns:mx="http://www.adobe.com/2006/mxml"
               layout="absolute"
               width="100%"
               minimum="0"
               maximum="100"
          <mx:Script>
               <![CDATA[
                    import mx.events.SliderEvent;
                    private function sliderChanged(_ : SliderEvent) : void {
                         trace("Slider changed");
          </mx:Script>
          </mx:Application>
          This does not print anything until I actually drag the slider.
          Evgeny
          • 2. Re: [not solved] The "change" event of a slider is fired on creation. How to modify this?
            vpxav Level 1
            Hello.
            First of all, thanks for trying to help and sorry for the late reply...
            If I doing like you, there is no problem but the thing is that you're not using a repeater.
            In my page, the slider is in a repeater and then I have my problem
            Thanks...
            • 3. Re: [not solved] The "change" event of a slider is fired on creation. How to modify this?
              Evgeniy_M Level 1
              Well, I tried putting the slider in the repeater (see the attachment), and again no change event is sent before I change them manually.
              Regardless, you can add the event listeners after the program creation is complete. Make a listener on creationComplete event and add the listener to the sliders in Actionscript.
              Evgeny
              • 4. Re: [not solved] The "change" event of a slider is fired on creation. How to modify this?
                Evgeniy_M Level 1
                Well, I tried putting the sliders in a repeater, and again no change event is sent until I change them manually.
                <mx:Application
                     layout="vertical"
                     backgroundColor="white"
                <mx:Array id="dp">
                     [10, 50, 20, 60]
                </mx:Array>
                <mx:Repeater id="infosRepeater" dataProvider="{dp}">
                <mx:HSlider
                     minimum="0"
                     maximum="100"
                     value="{infosRepeater.currentItem}"
                </mx:Repeater>
                <mx:Script>
                     <![CDATA[
                </mx:Script>
                </mx:Application>
                Regardless, you can add the listeners after the program initialization. Create a listener for creationComplete or some other late event and in it add the listener to each slider using Actionscript. For example,
                <mx:Application
                     layout="vertical"
                <mx:Array id="dp"> [1, 5, 2, 6] </mx:Array>
                <mx:HSlider value="{infosRepeater.currentItem}"/>
                </mx:Repeater>
                <mx:Button click="initSliders()"/>
                <mx:Script>
                     <![CDATA[
                          private function initSliders() : void {
                               for (var i : int = 0; i < numChildren; i++)
                                    if (getChildAt(i) is HSlider)
                                         getChildAt(i).addEventListener(SliderEvent.CHANGE, sliderChanged);
                </mx:Script>
                </mx:Application>
                Evgeny
