5 Replies Latest reply on Oct 7, 2006 12:04 AM by mcafe
    Resize object
    mcafe
      I got problem when resiz on movie clip. This some info hope that someone can help me.
      On the sreen the movie clip i put name as 'DisplayResult', the width = 200, height =50, x = 100, and y = 1000.
      When some button click, the DisplayResult need to resize into width = 400, height = 100, it succcess... but the x and y it run of... can i already try use script to fixed the x and y... it still run of. I want the movie clip on same position.
      Every button i click the size will x2 from original. This my code, are this effect the x, y??
      _root.DisplayResult.width = _root.DisplayResult.width *2
      _root.DisplayResult.height = _root.DisplayResult.Height *2
      _root.DisplayResult._x = 100
      _root.DisplayResult._y = 1000
      can someone tell me what problem happen??
      Thank you for speding time on my problem.
      Regards,
      Mc
        • 1. Re: Resize object
          crazyjoemilan Level 2
          is your movieclip embedded video? or just a standard flash mc? If its just a flash mc, use
          ._width
          and
          ._height
          If its embedded video, you have .Height (which should be .height)
          does that help?
          • 2. Re: Resize object
            rick1212
            It should look like this....
            _root.DisplayResult._width = _root.DisplayResult.width *2
            _root.DisplayResult._height = _root.DisplayResult.Height *2
            Use ._width to set a value and .width to get a value.
            Also, just some personal advice, try to stay away from the _root. Try useing _parent even if you have to 2 or 3 of them together to path back to where you need to be.
            • 3. Resize object
              mcafe Level 1
              Thank you for reply, this is Sample of what i means.
              I want to fixed to bar on left site, when each time i change the widht the position of the bar will run of can't statis stay at left site.
              Can someone help me on this problem, i search many topic about the widht, height, registration point, and so on. I still don't know what happen.
              Thank you and sorry for my problem. I hope someone can reply me asap, quite urgent i stuck on this part quite long.
              Regards,
              Mc
              • 4. Resize object
                mcafe Level 1
                quote:
                ._width
                and
                ._height
                does that help?
                Hi Mr Helpy,
                thank you for reply, i tester with it. Can't also, above it attach the sample what i means. Can help me see around?
                Regards,
                Mc
                Hi rick1212,
                Erm, i try both of them. It still can't. Can you help me see the sample above?? I put the sample there.
                Thank you.
                Regards,
                Mc
                • 5. Resize object
                  mcafe Level 1
                  Hi all,
                  thank you for spending time on my problem, the problem i alredy fix. The x,y on screen different when on script.
                  Regards,
                  Mc
