4 Replies Latest reply on Oct 12, 2009 11:57 AM by Handycam
    Using labelfunction to replace a label in grouped ADG
    Handycam Level 1
      I have an advanced datagrid with a grouping collection.
      The grouped label is a series of short phrases, to make the XML easier to read: 1h, 2h, 3h, etc.
      In the actual grid, though, I'd rather replace these with more user-friendly phrases: "One Hour", "Two Hours", "Three Hours", etc.
      what's the easiest and cleanest way to do this?
        • 1. Re: Using labelfunction to replace a label in grouped ADG
          Sameer Bhatt Adobe Employee
          Use AdvancedDataGrid.groupLabelFunction
          -Sameer
          • 2. Re: Using labelfunction to replace a label in grouped ADG
            Handycam Level 1
            Thanks.  Can you provide an example of how to use this to replace content?
            For example, if the current label is "1h" I want to replace that with "One
            Hour Before".
            • 3. Re: Using labelfunction to replace a label in grouped ADG
              Have a look at this code snippet -
                   <fx:Script>
                        <![CDATA[
                             import mx.controls.advancedDataGridClasses.AdvancedDataGridColumn;
                             private function grpLabelFunc(item:Object, col:AdvancedDataGridColumn):String
                                  // this field can be changed by setting the Grouping.label property
                                  var dataField:String = "GroupLabel";
                                  switch (item[dataField])
                                       case "1h": return "One Hour Before";
                                       case "2h": return "Two Hour Before";
                                       case "3h": return "Three Hour Before";
                                       case "4h": return "Four Hour Before";
                                  return item[dataField];
                   </fx:Script>
                   <fx:Declarations>
                        <fx:Array id="arr">
                             <fx:Object name="1h" />
                             <fx:Object name="2h" />
                             <fx:Object name="3h" />
                             <fx:Object name="4h" />
                        </fx:Array>
                   </fx:Declarations>
                   <mx:AdvancedDataGrid id="adg" groupLabelFunction="grpLabelFunc" creationComplete="gc.refresh()">
                        <mx:dataProvider>
                             <mx:GroupingCollection id="gc" source="">
                                  <mx:Grouping>
                                       <mx:GroupingField name="name" />
                                  </mx:Grouping>
                             </mx:GroupingCollection>
                        </mx:dataProvider>
                        <mx:columns>
                             <mx:AdvancedDataGridColumn dataField="name" />
                        </mx:columns>
                   </mx:AdvancedDataGrid>
              -Sameer
