4 Replies Latest reply on Oct 12, 2009 2:22 PM by Jim_Simon
    New RIG can you please have a quick look?
    xrayhead
      Hi All
      I’ve been running Premiere Pro CS3 for a while now and just can’t get it to run smoothly on my Quad core (Q6600 @ 240GHz with 4Gig of ram) when editing HD.
      So am looking to build a second rig at work to edit my HD and also do some gaming now and then. Can you please have a look at the spec I’ve come up with bellow and add any recommendations/comments?
      Case, power supply and Sound Card I have already so don’t need to sort that out!
      Many thanks
      Xray
      OVERCLOCKED -Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz @ 4.00GHz Max / Gigabyte EX58-UD5 Intel X58 Motherboard / Patriot Viper 6GB DDR3 PC3-12800C8 1600MHz DDR3 Bundle
      http://www.overclockers.co.uk/showproduct.php?prodid=BU-003-OB
      Graphics Card
      BFG GeForce GTX 275 OC 896MB GDDR3 PCI-Express Graphics Card
      http://www.overclockers.co.uk/showproduct.php?prodid=GX-086-BG
      Drive 1
      Western Digital VelociRaptor 300GB 10000RPM SATA-II 16MB Cache
      http://www.overclockers.co.uk/showproduct.php?prodid=HD-238-WD&groupid=701&catid=14&subcat =768
      Drive 2
      Western Digital WD7501AALS 750GB Hard Drive SATAII 7200rpm 32MB Cache
      http://www.ebuyer.com/product/146079
      Drive 3
      Optical Drives
      Samsung SH-S223L/RSMN 22x DVD±RW SATA Dual Layer Lightscribe ReWriter
      http://www.overclockers.co.uk/showproduct.php?prodid=CD-102-SA&groupid=701&catid=10&subcat =951
        • 1. Re: New RIG can you please have a quick look?
          Harm Millaard Level 7
          Looks good! Three remarks, maybe add another disk for exports and make sure you have a very good CPU cooler if you want to OC to 4 GHz, like a Thermalright Ultra-120 Extreme or a Noctua NH-U12P with push-pull fans. And add another 6 GB of memory to make the total 12 GB.
          • 2. Re: New RIG can you please have a quick look?
            xrayhead Level 1
            Only way I can go to 12 GB or RAM is to kill the OC, QUOTE (email I receved)
            Dear Xrayhead
            Unfortunately we can't add 12GB into the order sadly, because it would kill the overclock on the bundle - so there'd be no point in really going for it. I hope this helps you, and thanks for the web note.
            • 3. Re: New RIG can you please have a quick look?
              They have the Noctua cooler, so that is good. But the problem may be that the cooling ribs on the Patriot sticks may be too high for the CPU cooler and are rendering the 1-st DIMM slot useless, and thus the complete first bank of 3 DIMM slots. If that is their argument, maybe look at some other memory, because you are better off with 12 GB of memory and reducing your OC to 3.6 GHz than being limited to 6 GB. Their argument without a proper explanation looks at first sight to be utter BS. The Gigabyte is one of the best mobo's for overclocking, the Noctua in push-pull is the best cooler for stable OC-ing, so the only reason can be that the memory sticks are just hoo high physically. If you reduce your overclocking aspirations to around 3.6 GHz DDR3-1333 can be quite sufficient and will give you a lot more options.
              • 4. Re: New RIG can you please have a quick look?
                Jim_Simon Level 8
                I'd do the gaming on the current cimputer, only using the new one for video editing.
