11 Replies Latest reply on Oct 13, 2009 12:07 PM by shunithD
    Drop shadow is hard...
    shunithD Level 3
      AI CS3 on Win XP
      Must be doing something wrong... but can't figure out what...
      File size is 98x140cm
      Scene 1: RGB file. Drop shadow on a box is nice and soft. Headline has text with drop shadow.
      Scene 2: CMYK file. Same content (more or less) Drop shadow on headline is same as above. The catch. Everytime i try to create a shadow around the box, the shadow edges are hard.
      Have tried the following (not necessarily in order):
      1. Apply shadow to existing box -> shadow hard
      2. Create new box -> shadow hard
      3. Create new box - small -> shadow fine. Size up and shadow goes hard
      4. Create new file. Same as above
      5. Copy box from RGB file and paste. Shadow goes hard.
      Effect -> Stylize -> Drop Shadow
      Settings:
      Mode - Multiply
      Opacity - 75%
      X offset - 0.9cm
      Y offset - 0.9cm
      Blur - 0.9cm
      Color - shade of grey
      Darkness - unchecked
      Box size is 85x78 cm
      (I finally got around the problem by using a file where the box was large and drop shadow was ok and pasting the other content in... )
      Any thoughts?
      Cheers,
      SD
