3 Replies Latest reply on Oct 12, 2009 3:19 AM by mordsm
    Changing order of dislpayed vbox/hbox
    mordsm Level 1
      Hi All
      I have a hbox container that contains vbox , hbox
      depending on a condition I want to change the order of the display
      How this thing can be done?
      Moshe
        • 1. Re: Changing order of dislpayed vbox/hbox
          Francisc Level 3
          Hello!
          To move children around use setChildIndex.
          So if you mean that you have a parent HBox container with 2 children another HBox and a VBox, you would have to do this:
          <mx:HBox id="parentHBox" ...>
             <mx:HBox id="childHBox" ...>...</mx:HBox>
             <mx:VBox id="childVBox" ...>...</mx:VBox>
          </mx:HBox>
          And the following ActionScript code you need to place in the IF statement or click action of the button that rearranges them:
          parentHBox.setChildIndex(childHBox,parentHBox.getChildIndex(childHBox) + 1);
          The above example moved the HBox child under the VBox.
          Note: You can use plus or minus operations, for example if you wanted to move the VBox over the HBox for the above MXML example you would write:
          parentHBox.setChildIndex(childVBox,parentHBox.getChildIndex(childVBox) - 1);
          • 2. Re: Changing order of dislpayed vbox/hbox
            kkc_mca Level 2
            I hope you are declaring VBox and HBox as MXML tags
            Declare those in the script tag and depending on the condition add the VBox and HBox to the container
            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical" applicationComplete="init()">
            <mx:Script>
            <![CDATA[
            import mx.controls.Alert;
            public var myVBox:VBox;
            public var myHBox:HBox;
            public function init():void
            myVBox=new VBox();
            myHBox=new HBox();
            // need to perform the required action
            if(true)
            addChild(myVBox);  // first vbox
            addChild(myHBox);  // second hbox
            else
            addChild(myHBox); // first hbox
            addChild(myVBox); // second vbox
            </mx:Script>
            </mx:Application>
            if this post answers your question or helps, Please mark it as such .
            • 3. Re: Changing order of dislpayed vbox/hbox
              mordsm Level 1
              while the abobe answers gave me nice insights /solutions I made another solution
              I changed the container to canvas and then using a condition I position my vbox /hbox like this
              <vbox ....... x = "{(condition?280:0}"
              Moshe
