1 Reply Latest reply on Oct 20, 2009 11:46 AM by Jason San Jose
    Content Assist in Flash Builder Beta 2
    zilet
      Hi All,
        I am using Flash Builder as a plugin to eclipse. With this new release from time to time I am getting Content Assist errors and the only resolution is to restart Eclipse.
        The error that I am getting from the log is following:
      !ENTRY org.eclipse.ui 4 4 2009-10-12 12:51:21.800
      !MESSAGE "Content Assist" did not complete normally.  Please see the log for more information.
      !ENTRY org.eclipse.ui 4 0 2009-10-12 12:51:21.800
      !MESSAGE java.lang.NullPointerException
      !STACK 0
      at com.adobe.flexbuilder.codemodel.internal.asdoc.ClassCommentRef.<init>(ClassCommentRef.jav a:36)
      at com.adobe.flexbuilder.codemodel.internal.tree.ClassNode.getDynamicCommentRef(ClassNode.ja va:779)
      at com.adobe.flexbuilder.codemodel.internal.tree.BaseDefinitionNode.getComment(BaseDefinitio nNode.java:334)
      at com.adobe.flexide.as.core.contentassist.ActionScriptCompletionProposal.<init>(ActionScrip tCompletionProposal.java:151)
      at com.adobe.flexide.as.core.contentassist.ActionScriptCompletionProcessor.getTypeProposal(A ctionScriptCompletionProcessor.java:691)
      at com.adobe.flexide.as.core.contentassist.ActionScriptCompletionProcessor.createProposalsFr omDefinitions(ActionScriptCompletionProcessor.java:952)
      at com.adobe.flexide.as.core.contentassist.ActionScriptCompletionProcessor.createLocalPropos als(ActionScriptCompletionProcessor.java:786)
      at com.adobe.flexide.as.core.contentassist.ActionScriptCompletionProcessor.computeCompletion Proposals(ActionScriptCompletionProcessor.java:1142)
      at org.eclipse.jface.text.contentassist.ContentAssistant.computeCompletionProposals(ContentA ssistant.java:1832)
      at org.eclipse.jface.text.contentassist.CompletionProposalPopup.computeProposals(CompletionP roposalPopup.java:556)
      at org.eclipse.jface.text.contentassist.CompletionProposalPopup.access$16(CompletionProposal Popup.java:553)
      at org.eclipse.jface.text.contentassist.CompletionProposalPopup$2.run(CompletionProposalPopu p.java:488)
      at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
      at org.eclipse.jface.text.contentassist.CompletionProposalPopup.showProposals(CompletionProp osalPopup.java:482)
      at org.eclipse.jface.text.contentassist.ContentAssistant.showPossibleCompletions(ContentAssi stant.java:1660)
      at org.eclipse.jface.text.source.SourceViewer.doOperation(SourceViewer.java:835)
      at org.eclipse.jface.text.source.projection.ProjectionViewer.doOperation(ProjectionViewer.ja va:1533)
      at com.adobe.flexide.editorcore.editor.FlexSourceViewer.doOperation(FlexSourceViewer.java:17 6)
      at org.eclipse.ui.texteditor.TextOperationAction$1.run(TextOperationAction.java:131)
      at org.eclipse.ui.texteditor.TextOperationAction.run(TextOperationAction.java:129)
      at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
      at org.eclipse.ui.commands.ActionHandler.execute(ActionHandler.java:185)
      at org.eclipse.ui.internal.handlers.LegacyHandlerWrapper.execute(LegacyHandlerWrapper.java:1 09)
      at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
      at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.jav a:508)
      at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
      at org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeCommand(WorkbenchKeyboard.java:470)
      at org.eclipse.ui.internal.keys.WorkbenchKeyboard.press(WorkbenchKeyboard.java:824)
      at org.eclipse.ui.internal.keys.WorkbenchKeyboard.processKeyEvent(WorkbenchKeyboard.java:880 )
      at org.eclipse.ui.internal.keys.WorkbenchKeyboard.filterKeySequenceBindings(WorkbenchKeyboar d.java:569)
      at org.eclipse.ui.internal.keys.WorkbenchKeyboard.access$3(WorkbenchKeyboard.java:510)
      at org.eclipse.ui.internal.keys.WorkbenchKeyboard$KeyDownFilter.handleEvent(WorkbenchKeyboar d.java:125)
      at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
      at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1191)
      at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1002)
      at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
      at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1012)
      at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1040)
      at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1036)
      at org.eclipse.swt.widgets.Widget.wmChar(Widget.java:1368)
      at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:4053)
      at org.eclipse.swt.widgets.Canvas.WM_CHAR(Canvas.java:346)
      at org.eclipse.swt.widgets.Control.windowProc(Control.java:3946)
      at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:342)
      at org.eclipse.swt.widgets.Display.windowProc(Display.java:4589)
      at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
      at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2410)
      at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3471)
      at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
      at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
      at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
      at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
      at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
      at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
      at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
      at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
      at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
      at java.lang.reflect.Method.invoke(Method.java:597)
      at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
      at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
      at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
      at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
