5 Replies Latest reply on Jul 18, 2008 3:47 PM by bregent
    CDO Form mailer: Using Verio's instructions
    bkrboy@chartermi.net Level 1
      I used verios instructions to create a code as I was instructed.
      I get this error message:
      Microsoft VBScript compilation error '800a0401'
      Expected end of statement
      /index_files/emailer.asp, line 26
      Dim Flds Const cdoSendUsingPort = 2
      This is my entire code:
      <!--METADATA TYPE="typelib" UUID="CD000000-8B95-11D1-82DB-00C04FB1625D" NAME="CDO for Windows Library" -->
      <!--METADATA TYPE="typelib" UUID="00000205-0000-0010-8000-00AA006D2EA4" NAME="ADODB Type Library" -->
      DIM objCDO
      Set objCDO = Server.Createobject("CDO.Message")
      <% Set objCDO = Nothing %>
      myMail.From = "info@walkwithhim.org"
      myMail.To = "bkrboy@chartermi.net"
      myMail.Subject = "Story"
      myMail.TextBody = "Here is a story from the website"
      myMail.Send
      Dim objConf
      Set objConf = Server.CreateObject("CDO.Configuration")
      Set Flds = iConf.Fields
      With Flds
      .Item(cdoSendUsingMethod) = cdoSendUsingPort
      .Item(cdoSMTPServer) = "mail-fwd"
      .Item(cdoSMTPServerPort) = 25
      .Item(cdoSMTPconnectiontimeout) = 10
      .Update
      End With
      http://www.verio.com/support/documents/view_article.cfm?doc_id=3894
      I got the instructions from the page above:
      Can you look at my code and see if there is any errors?
      Thanks SO much!
        • 1. Re: CDO Form mailer: Using Verio's instructions
          Level 7
          Try putting this on 2 lines:
          Like this:
          Dim Flds
          Ken Ford
          Adobe Community Expert - Dreamweaver/ColdFusion
          Fordwebs, LLC
          http://www.fordwebs.com
          "bkrboy@chartermi.net" <webforumsuser@macromedia.com> wrote in message news:g5oe7c$jl3$1@forums.macromedia.com...
          > DIM objCDO
          > myMail.Send
          > Dim objConf
          > With Flds
          > .Update
          > End With
          > Thanks SO much!
          • 2. Re: CDO Form mailer: Using Verio's instructions
            I don't understand. Do i add this or where do i put it?
            • 3. Re: CDO Form mailer: Using Verio's instructions
              Level 7
              Right now you have this:
              With Flds
              .Update
              End With
              Try changing it to this:
              Dim Flds
              With Flds
              .Update
              End With
              Ken Ford
              Fordwebs, LLC
              "bkrboy@chartermi.net" <webforumsuser@macromedia.com> wrote in message news:g5qaop$mk1$1@forums.macromedia.com...
              • 4. Re: CDO Form mailer: Using Verio's instructions
                Ms. Casey
                Can I copy this code to send the form data to a database? Or is that a different code?
                Casey
                • 5. Re: CDO Form mailer: Using Verio's instructions
                  bregent Most Valuable Participant
                  It's completely different code. The OP is trying to send mail from a form.
