2. Re: Why can I not select the transparency flattener preset option when exporting to a pdf?
M.Jay.Victor Oct 12, 2009 11:00 AM (in response to designerdave72)The preset you are using is exporting to a PDF type that supports transparency, so it does not flatten. If you use X1a for example though, you will have the option again.
3. Re: Why can I not select the transparency flattener preset option when exporting to a pdf?
Petteri_Paananen Oct 12, 2009 11:03 AM (in response to Talyianna)That´s excellent article and solution is there if you read whole thing carefully. I just mention that sloution here too because it´s very simple; make sure that your PDF compatibility is set to Acrobat 4 (PDF 1.3). If you use any other choice, your transparencies will go to PDF as live transparency and transparency flattener is not used (nor presets of it). And whole feature is deactivated in PDF Export window.
4. Re: Why can I not select the transparency flattener preset option when exporting to a pdf?
Talyianna Oct 12, 2009 11:10 AM (in response to designerdave72)DesignerDave72,
Thank you SO MUCH!!
I have been battling with this for over an hour...and it was frustrating me no end. 1 minute into reading the article you suggested and I was home free!! THANK YOU...!! You're my hero!
Best regards,
Christine
5. Re: Why can I not select the transparency flattener preset option when exporting to a pdf?
designerdave72 Oct 12, 2009 11:34 PM (in response to Talyianna)No worries, we're all here to help
