3 Replies Latest reply on Oct 13, 2009 7:16 AM by kglad
    Communicate between loaded SWF's
    richiebeno Level 1
      I have a base SWF, and I am loading a another SWF into a movieClip array... i need to communicate from the loaded SWF to the base SWF i tried _root but think this only goes to the root of the loaded movieClip any ideas?
      This is what I tried:
      on (release) {
      _root.moveContent(2);
      thanks in advance
      Rich
        • 1. Re: Communicate between loaded SWF's
          _root always refers to the current _levels main timeline.  your main swf is always in _level0.  unless you load a swf into another _level, _root will always reference the main timeline of your main (or loading) swf.
          you can reference the main timeline of the loaded swf by referencing the target movieclip into which the swf was loaded.
          • 2. Re: Communicate between loaded SWF's
            richiebeno Level 1
            I don't think I explained correctly... I have a base SWF (index.swf) which I load another SWF into (home.swf) I need action in the home.swf to go to the main timeline in index.swf
            Thanks in advance for any further help
            • 3. Re: Communicate between loaded SWF's
              again, if home.swf is loaded into a target movieclip, _root or _level0 will reference the index main timeline.
              if home.swf is loaded into a non-zero _level, then _level0 only will reference index'es main timeline.
