4 Replies Latest reply on Oct 14, 2009 4:11 AM by AntonyM6-sPksqC
    importing R3D red files into AE that have discrete independent audio channels inside
    ideami
      i have an R3D file (Red One Camera) with two audio channels inside
      channel 1 is empty
      channel 2 has audio from a clipon microphone
      problem is when i import this file into after effects, no audio is imported,
      it is as if after effects considered only channel 1 as the audio source
      so the question is, if i have an R3D file with independent discrete audio channels inside, how can i import that into after effects maintaining those audio channels independent of each other without having AE mix them and blend them?
      in fact AE is not even mixing them, it is picking channel 1, which is empty, and discarding channel 2, which has the audio in it, crazy..
      thank you so much for any help you can give me
      best
      Javier
