1 Reply Latest reply on Oct 13, 2009 3:15 AM by Subeesh Arakkan
    How do I remove a selected item from a datagrid?
    xandesign
      Hi all,
      I have a datagrid in my flex project which has a checkbox on each row which allows the user to select a row for deletion. I have a actionscript function which loops through all items looking for a selected item to remove but I don't know how to remove the selected item from the datagrid once found.
      Can someone tell me how I can remove selected items from my datagrid?
      I've included the code from my function below, any help would be much appreciated.
      Thanks in advance,
      Xander
      * Delete button click event.
      private function deleteClick():void {
      var selectedItems:ArrayCollection = sectionDatagrid.dataProvider as ArrayCollection;
      var deleteArray:Array = new Array();
      var index:int = 0;
      for each (var item:Object in selectedItems) {
      if (item.selected == true) {
      deleteArray[index] = "DELETE FROM core_resources WHERE iid=" + item.iid + ";";
      index++;
      //insert code here to remove selected item
        • 1. Re: How do I remove a selected item from a datagrid?
          Subeesh Arakkan Level 4
          var dp:ArrayCollection= new ArrayCollection();
               deleteArray.push(item);
          else
               dp.addItem(item);
          sectionDatagrid.dataProvider = dp;
