4 Replies Latest reply on Oct 18, 2009 8:39 AM by AdobeScripts
    Change itemLink
    NgoiSang88888
      I want to change the itemLink paramtere of a Story but this is a read-only property, how can I do this? Or more generally: how can I link a file to a story in
      InDesign with Indesign Script.
      PS I'm using JavaScript
        • 1. Re: Change itemLink
          You cannot change the link from one file to another. If you could, you could create a file out of nothing (by setting the link to a non-existing file).
          The other way around you can use document.place (filename) -- be sure the TextPreference linkTextFilesWhenImporting is set to true to get a link.
          What are you trying to achieve?
          • 2. Re: Change itemLink
            NgoiSang88888 Level 1
            I have a masterpage with our textframes in one Story. I want to add new pages to the document with this master applied. Cosecutively I want to link a file to this story (a docx-file). There is not already a file linked to the Story.
            • 3. Re: Change itemLink
              I see I can place it with document.place, but then I have to assign it to a Story manually and that is not what I want...
              Somebody?
              • 4. Re: Change itemLink
                AdobeScripts Level 3
                when you place file - you get reference to it
                or you can first create "container" and place your file into it
                so in your case - you can (VB example):
                1) create new TextFrame
                Set myTF = myDoc.Pages.Item(1).TextFrames.Add
                2) place your text file to .ParentStory.Texts.Item(1) of this new TextFrame
                call myTF.ParentStory.Texts.Item(1).Place("c:\qqq.txt")
                3) connect your destination story's LastTextFrame with this new TextFrame
                (for ID CSx < 3)
                myMainStory.TextFrames.Item(-1).NextTextFrame = myTF
                or
                (for ID CSx > 2)
                myMainStory.TextContainers.Item(-1).NextTextFrame = myTF
                4) delete myTF and reflow your myMainStory
                robin
                www.adobescripts.co.uk
