1 Reply Latest reply on Oct 14, 2009 8:44 AM by msakrejda
    Using my objects as keys in a hash map
    sam_bercovici
      I need the following type of code to work (ClDate is my own class):
                  var testDic:Dictionary = new Dictionary();
                  var key1:ClDate = new ClDate(10000);
                  var key2:ClDate = new ClDate(20000);
                  var key3:ClDate = new ClDate(30000);
                  var key4:ClDate = new ClDate(40000);
                  testDic[key1] = 1;
                  testDic[key2] = 2;
                  testDic[key3] = 3;
                  testDic[key4] = 4;
                  var key:ClDate = new ClDate(20000);
                  var retNum:Number = testDic[key];
      The current Dictionary or Array does not work since they do not enable passing a comparison function that will enable comparing my own objects. Is there any existing implementation that works?
      -Sam.
        • 1. Re: Using my objects as keys in a hash map
          msakrejda Level 4
          Object (when acting as a map) uses toString() as a poor man's hashcode implementation, so you can get more-or-less the behavior you want by implementing the toString() method in your CIDate class and then storing the instances in an Object (rather than a Dictionary).
          E.g., say your CIDate looks like this:
                    public class CIDate {
                      public var num:Number
                      public function CIDate(num:Number) { this.num = num }
                      public function toString():String { return num.toString(); }
          You can use toString() as a comparison operator by keeping things in an Object instead of a Dictionary:
                      var testDic:Object = {};
                      testDic[key1] = 1;
                      testDic[key2] = 2;
                      testDic[key3] = 3;
                      testDic[key4] = 4;
          Then retNum should be '2', as expected. This is sort of a hack, but it might work for what you're doing.
