4 Replies Latest reply on Oct 18, 2009 10:31 AM by shunithD
    Rounded corners + resize rectangle
    shunithD Level 3
      How does one stop the rounded corners from degrading while resizing a rectangle with rounded corners?
        • 1. Re: Rounded corners + resize rectangle
          JETalmage Level 6
          You don't.
          Incredible as it seems, after two and a half decades, this dog of a program still does not contain the kind of live shape primitives tools (Ellipses, Rectangles, Polygons, Stars, others, with editable geometric parameters) you expect in any drawing program.
          There is a completely unintuitive feature that lets you "convert" a fill or a stroke (or path) to a rounded rectangle with live geometry. Draw the path with any tool, (but it makes sense to use the Rectangle Tool), Select Effect>ConvertToShape>RoundedRectangle. Enter zero in both Add Space fields.
          JET
          • 2. Re: Rounded corners + resize rectangle
            marlaau Level 1
            An added benifit to usng Effect>ConvertToShape>RoundedRectangle is that you can change the Corner Radius at any time using the Appearance Panel.
            If for some reason you have to have the rounded rectangel as a path and not as an  "effect" just select the rectangle and Expand Appearance.   You can go back and use the Effect>ConvertToShape>RoundedRectangle again if you want then back to Expand Appearance go back and forth as often as you like.
            Just remember if you want the corners to expand - resize the "Expand Appearance" object
            If you want the corners to keep the same radius - resize the "Effect>ConvertToShape>RoundedRectangle" object
            • 3. Re: Rounded corners + resize rectangle
              shunithD Level 3
              Thanks Jet / Marlaau...
              • 4. Re: Rounded corners + resize rectangle
                shunithD Level 3
                Jet / Marlaau...
                That seems to work . But seems strange that when you create a rounded rectangle using the Rectangle Tool the problem arises...
                Thanks again...
