3 Replies Latest reply on Jan 6, 2010 7:58 AM by cdman522
    Command Line Build - Java heap space error
    jhndnn
      I'm attempting to build a Flex app via the command line. Even though the build works fine from within the Flash Builder IDE, I get the following error when I attempt to build via the command line
      C:\code\software\web_stuff>"C:\Program Files\Adobe\Adobe Flash Builder Beta 2\FlashBuilderC.exe" --launcher.suppressErrors -noSplash -application org.eclipse.ant.core.antRunner -data "C:\code\software\web_stuff" -file C:\code\software\web_stuff\build.xml WebControlBrowser
      Buildfile: C:\code\software\web_stuff\build.xml
      WebControlBrowser:
      [fb.exportReleaseBuild] Compiling 1 application to C:\code\software\web_stuff\WebControlBrowser\bin-release...
      [fb.exportReleaseBuild] Exception in thread "Code Model Worker" java.lang.OutOfMemoryError: Java heap space
      [fb.exportReleaseBuild]         at org.eclipse.core.internal.runtime.InternalPlatform.getLog(InternalPlatform.java:404)
      [fb.exportReleaseBuild]         at org.eclipse.core.runtime.Plugin.getLog(Plugin.java:282)
      [fb.exportReleaseBuild]         at com.adobe.flexbuilder.codemodel.internal.bridge.WorkspaceSpecification.log(WorkspaceS
      pecification.java:136)
      [fb.exportReleaseBuild]         at com.adobe.flexbuilder.codemodel.internal.parsing.ASTokenizer.parseTokens(ASTokenizer.
      java:386)
      [fb.exportReleaseBuild]         at com.adobe.flexbuilder.codemodel.internal.search.SWCSearchDataProvider.indexFiles(SWCS
      earchDataProvider.java:440)
      [fb.exportReleaseBuild]         at com.adobe.flexbuilder.codemodel.internal.search.SWCSearchDataProvider$2.run(SWCSearch
      DataProvider.java:364)
      [fb.exportReleaseBuild]         at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
      [fb.exportReleaseBuild]         at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
      [fb.exportReleaseBuild]         at java.lang.Thread.run(Unknown Source)
      BUILD FAILED
      C:\code\software\web_stuff\build.xml:4: java.lang.OutOfMemoryError: Java heap space
      Total time: 1 minute 0 seconds
      FlashBuilderC:
      An error has occurred. See the log file
      C:\code\software\web_stuff\.metadata\.log.
      I've attached the .log file that is referenced.
