1 Reply Latest reply on Oct 26, 2009 3:15 AM by $Nith$
    Java in Livecycle to check required fields then submit
    pittfan2
      Has anyone created a fake email button to check for required fields such as LastName, FirstName, EffectiveDate, EmployeeNo. and then execute an event on a button?
      I have a form where I have written Java programming on a button to email the form and include field names (see below):
      var oDoc = event.target;
      oDoc.mailDoc({
          bUI: false,
          cTo: test@test.com ,
          cBcc: "bcc@bcc.com; test@test.com" ,
          cSubject: "PNF for " + LastName.rawValue + ", " + FirstName.rawValue + " : Reason - " + ReasonforChg.rawValue + " (" + ReasonCodes.rawValue + ") "
      I would like to keep this but have lost the check for required fields since I am not using it as a submit button.  I am trying to create a button that checks for required fields then executes the script on the button to email the form.
      Can anyone help me?
        • 1. Re: Java in Livecycle to check required fields then submit
          $Nith$ Level 4
          Did you try to use the if else construct?
          if(someField.rawValue == null  || someField.rawValue=='')
               app.alert('Please fill the required fields and click submit');
          }else{
          //your previous lines of code
          oDoc.mailDoc({
              bUI: false,
          Nith
