6 Replies Latest reply on Oct 14, 2009 3:03 PM by Harm Millaard
    .AVI Weird Editing Issuse, Help!
    Mks23
      Hi I recently attempted to edit some "That Mitchell and Webb Episodes" which are:
      File Type: .avi
      Video:
      Frame Width: 720
      Frame Height: 404
      Data Rate: 1406kbps
      Total Bitrate: 1566kbps
      Frame Rate: 25 fps
      Audio:
      Bitrate: 160kbps
      Channels: 2 (stereo)
      Audio Sample Rate: 48kHz
      I started a simple project using the "Sequence Preset" of "DV-PAL, Widescreen 48kHz", and then imported the first episode.
      it said something along the lines of Premiere Pro requires a codec to edit and play this file type will you allow it to download and install it, I click yes waited 5 minutes for it to do so, the restarted it and now I can here the audio of the file correctly corresponding to where the playhead is if I drag the playhead to the begining the video displayed will be at the correct place but if I drag it to the end it only shows me 18 seconds in to the episode when the playhead is at 29 minutes and 26 seconds.
      http://i33.tinypic.com/2d6lhj7.jpg
      http://i34.tinypic.com/xbme69.jpg
      http://i34.tinypic.com/34xfh1i.jpg
