2 Replies Latest reply on Oct 14, 2009 10:32 PM by edsager-NDxnfr
    Button image: bring to front?
    edsager-NDxnfr Level 1
      Hello,
      I have 3 images converted to buttons, each of which grows in size when hovering over each.  The larger-sized image is supposed to cover the other smaller-sized image buttons.  I can get up to 2 of the larger-sized image buttons to cover at least one of the smaller-sized image buttons, but that is it.
      Is there a way in FC to send to back and bring to front images when they are hovered over?
      Thank you,
      edsager
        • 1. Re: Button image: bring to front?
          acath Level 4
          Hi Edgsager,
          Unfortunately, there's no way to do that directly in Catalyst. Here are two workarounds:
          1) Import the project into Flash Builder, then write some code to set the "depth" property on rollover. Higher depth = more in front of other things.
          2) Do a bait-and-switch. Create your 3 larger images on top of your 3 buttons, and hide the larger images. When the buttons are rolled over, play a state transition or action sequence to animate the larger images appearing over the buttons.
          Good luck!
          -Adam
          • 2. Re: Button image: bring to front?
            Hello Adam:
            Excellent!  Thank you!
            edsager
