1 Reply Latest reply on Oct 15, 2009 12:27 AM by Subeesh Arakkan
    DataGrid Header Problem
    srib Level 1
      Dear All,
      I have some problem with accessing DataGrid HeaderText, When one column is visable false.
      "Click on column content and the code will show col # and header name. Do the same After Hide Colun  is clicked"
      Please check the following code
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
      <mx:Script>
          <![CDATA[
              import mx.controls.listClasses.BaseListData;
              import mx.controls.dataGridClasses.DataGridListData;
              import mx.controls.dataGridClasses.DataGridItemRenderer;
              import mx.events.ListEvent;
              import mx.controls.*;
              function grd_click(e:ListEvent):void{
                      var icol:int = e.columnIndex;
                      var column:DataGridColumn = DataGridColumn(grid1.columns[icol]);
                      var headerTxt:String = column.headerText;
                      Alert.show("Header text = " + headerTxt)
              function hideCol(index:int):void{
                    var c:DataGridColumn = DataGridColumn(grid1.columns[index]);
                    c.visible = false;
              var items:Array = [
                  {name:"vlad",lname:"collak"},
      </mx:Script>
          <!--<mx:DataGrid x="90" y="99" itemClick="test(event)" id="grid1" dataProvider="{items}">-->
          <mx:DataGrid x="90" y="99" itemClick="grd_click(event)" id="grid1" dataProvider="{items}">
              <mx:columns>
                  <mx:DataGridColumn headerText="Column 1" dataField="name"/>
                  <mx:DataGridColumn headerText="Column 2" dataField="lname"/>
              </mx:columns>
          </mx:DataGrid>
          <mx:Button x="90" y="262" label="Hide Column" click="hideCol(0)"/>
          <mx:Label x="90" y="56" text="Click on column content and the code will show col # and header name. Do the same After Hide Colun  is clicked" width="642" height="35"/>
      </mx:Application>
      Regards,
      Sri
        • 1. Re: DataGrid Header Problem
          Subeesh Arakkan Level 4
          I think the column still exists even if you set its visibility to false. You could try something like this
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" xmlns:local="*">
              <mx:Script>
              <![CDATA[
                  private function grd_click(e:ListEvent):void{
                  private function hideCol(index:int):void{
                    if(index == 0)
                        grid1.columns = [column1];
                    else
                        grid1.columns = [column2];
                  [Bindable]private var items:Array = [
          </mx:Script>
                  <mx:columns>
                      <mx:DataGridColumn id="column1" headerText="Column 1" dataField="name" />
                      <mx:DataGridColumn id="column2" headerText="Column 2" dataField="lname"/>
                  </mx:columns>
              </mx:DataGrid>
          </mx:Application>
