11 Replies Latest reply on Oct 17, 2009 4:25 AM by erthy
    Flex marking a sample code invalid "Access of undefined property"?
    erthy Level 1
      Hey,
      I used the code from this link: http://tdotblog.info/?q=node/6
      When i put it into Flex Builder 3, it has several issues with the code like "Access of undefined property FileStream" (or File).
      When I run the application, only the typical gray background appears.
      What am I doing wrong?
      Thanks, Erthy
        • 1. Re: Flex marking a sample code invalid "Access of undefined property"?
          Subeesh Arakkan Level 4
          Did you import it as an AIR app or Flex App ? File and FileStream classes are only available for AIR
          • 2. Re: Flex marking a sample code invalid "Access of undefined property"?
            erthy Level 1
            I did not import it, I just made a new project -> desktop application and pasted the code...
            When I tried to import it, I started a new project and i set the directory to the downloaded directory.
            Am I doing something wrong?
            • 3. Re: Flex marking a sample code invalid "Access of undefined property"?
              erthy Level 1
              This is the code:
              <mx:WindowedApplication xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
              <mx:Script>
                   <![CDATA[
                        import mx.controls.Alert;
                        private function loadXML():void{
                             var file = new File();
                             file.addEventListener(Event.SELECT, dirSelected);
                             file.browseForOpen("Select person.xml file");
                        private function dirSelected(e:Event):void {
                             if(file.nativePath.indexOf("person.xml") != -1){
                                  var fs:FileStream = new FileStream();
                                  fs.open(file, FileMode.READ);
                                   var personXML = XML(fs.readUTFBytes(fs.bytesAvailable));
                                  fs.close();
                                  setTextInputs();
                             }else{
                                  Alert.show("You have not selected an xml file called 'person.xml'");
                        private function setTextInputs():void{
                             fName_txti.text = personXML.firstName;
                             lName_txti.text = personXML.lastName;
                             save_btn.enabled = true;
                        private function saveXML():void{
                             personXML.firstName = fName_txti.text;
                             personXML.lastName = lName_txti.text;
                             var newXMLStr:String = "<?xml version=\"1.0\" encoding=\"UTF-8\"?>" + personXML.toXMLString();
                             fs.open(file, FileMode.WRITE);
                             fs.writeUTFBytes(newXMLStr);
                             fs.close();
              </mx:Script>
              <mx:VBox>
              <mx:HBox>
              <mx:Label text="First Name:"/>
              <mx:TextInput id="fName_txti"/>
              </mx:HBox>
              <mx:HBox>
              <mx:Label text="Last Name:"/>
              <mx:TextInput id="lName_txti"/>
              </mx:HBox>
              <mx:HBox>
              <mx:Button id="load_btn" label="Load XML" click="loadXML()"/>
              <mx:Button id="save_btn" label="Save XML" click="saveXML()" enabled="false"/>
              </mx:HBox>
              </mx:VBox>
              </mx:WindowedApplication>
              And it keeps saying: "Access of undefined property file" and "Access of undefined property personXML"
              What is wrong?
              • 4. Re: Flex marking a sample code invalid "Access of undefined property"?
                Looks like the downloaded example is not complete. If you are looking for a simple xml read/write in AIR, check this post
                http://www.adobe.com/devnet/air/flex/quickstart/xml_prefs.html
                • 5. Re: Flex marking a sample code invalid "Access of undefined property"?
                  erthy Level 1
                  When i import the project, Flex Builder says it is not a valid project.
                  When i run the PrefsXMLDemoFlex.xml through the adl.exe, nothing shows up.
                  What is my problem?
                  • 6. Re: Flex marking a sample code invalid "Access of undefined property"?
                    Create new application , copy and paste the code from the main application file in the example downloaded. It worked for me
                    • 7. Re: Flex marking a sample code invalid "Access of undefined property"?
                      erthy Level 1
                      Yes! The application is running!
                      Would you be ok, if I asked other questions in this topic as I try to put the code to use?
                      • 9. Re: Flex marking a sample code invalid "Access of undefined property"?
                        erthy Level 1
                        OK, so I used the code (btw thanks for the link, it is awesome, i already marked as much answers and helpful answers I could) and I came up with something like this:
                             <mx:Script>
                                  <![CDATA[
                                       import flash.filesystem.*;
                                       public var prefsFile:File; // The preferences prefsFile
                                       [Bindable] public var prefsXML:XML; // The XML data
                                       public var stream:FileStream; // The FileStream object used to read and write prefsFile data.
                                       public function starter():void
                                       // stage.nativeWindow.addEventListener(Event.CLOSING, windowClosingHandler);
                                       prefsFile = File.applicationStorageDirectory;
                                       prefsFile = prefsFile.resolvePath("slovnik.xml");
                                       readXML();
                                       private function readXML():void
                                       stream = new FileStream();
                                       if (prefsFile.exists) {
                                           stream.open(prefsFile, FileMode.READ);
                                           processXMLData();
                                       else
                                           Alert.show("Nenalezeny žádné slovníky!");
                                       // stage.nativeWindow.visible = true;
                                       private function processXMLData():void
                                       prefsXML = XML(stream.readUTFBytes(stream.bytesAvailable));
                                       stream.close();
                                       // var slovicko = prefsXML.slovicko.cs;
                                       Alert.show("Česky je to: " + prefsXML.slovicko.@cs + "\n Anglicky je to: " + prefsXML.slovicko.@en);
                                       // stage.nativeWindow.x = prefsXML.windowState.@x;
                                       // stage.nativeWindow.y = prefsXML.windowState.@y;
                                       // stage.nativeWindow.width = prefsXML.windowState.@width;
                                       // stage.nativeWindow.height = prefsXML.windowState.@height;
                                       private function writer():void
                                       createXMLData();
                                       writeXMLData();
                                       private function createXMLData():void
                                       prefsXML = <slovicka/>;
                                       prefsXML.slovicko.@id = 2;
                                       prefsXML.slovicko.@cs = "kočka";
                                       prefsXML.slovicko.@en = "cat";
                                       // prefsXML.windowState.@width = stage.nativeWindow.width;
                                       // prefsXML.windowState.@height = stage.nativeWindow.height;
                                       // prefsXML.windowState.@x = stage.nativeWindow.x;
                                       // prefsXML.windowState.@y = stage.nativeWindow.y;
                                       // prefsXML.saveDate = new Date().toString();
                                       private function writeXMLData():void
                                       var outputString:String = '<?xml version="1.0" encoding="utf-8"?>\n';
                                       outputString += prefsXML.toXMLString();
                                       outputString = outputString.replace(/\n/g, File.lineEnding);
                                       stream.open(prefsFile, FileMode.WRITE);
                                       stream.writeUTFBytes(outputString);
                                       stream.close();
                             </mx:Script>
                             <mx:Button id="start" label="Start" width="130"
                                          click="starter()"/>
                            <mx:Button id="write" label="Write" width="130"
                                          click="writer()" x="138"/>
                        However, when I change the value, it overwrites the contents of the file. How can I just add one more "slovicko" element to the XML, so it would look like this:
                        <slovicka>
                          <slovicko id="1" cs="blah" en="blah" />
                          <slovicko id="2" cs="kočka" en="cat"/>
                        </slovicka>
                        after adding a new element, instead of just overwriting the previous content leaving only the id=2 element.
                        Thanks, I failed to find it and I am sorry for my English.
                        • 11. Re: Flex marking a sample code invalid "Access of undefined property"?
                          erthy Level 1
                          Hey, I am trying to ask for a part of the XML file, and I want to change the variables I use to do that. In short words, why is my code not working?:
                          var slid = 3;
                          var lang = "en";
                          var slovicko = slovnikXML.slovicko.(@id == [slid]).@[lang];
                          Alert.show("Slovíčko je: " + slovicko);
                          even though this:
                          var slid = 3;
                          var lang = "en";
                          var slovicko = slovnikXML.slovicko.(@id == 3).@en;
                          is working perfectly --> not a problem in the slovnikXML variable.
                          this also works:
                          var slid = 3;
                          var lang = "en";
                          var slovicko = slovnikXML.slovicko.(@id == 3).@[lang];
                          So the probelm is somewhere around the @id part...
                          Any suggestions?
                          Thanks!
