1 Reply Latest reply on Oct 15, 2009 11:38 AM by Techfu
    Need help creating horizontal scrollbar in graphic timelime (built in AI)!
    lcrumbley
      I am trying to use Catlyst to build an interactive scrollbar on a graphic timeline build in Adobe Illustrator,  I want to be able to scroll from one end of timeline to the other.  Can anyone help?  Thanks!
        • 1. Re: Need help creating horizontal scrollbar in graphic timelime (built in AI)!
          Techfu Level 1
          Can you post a screenshot of the timeline you are trying to convert. It will help in accurate response.
          You would probably need to do it in two step:
          - Have the graphic timeline converted into Datalist element, and make the data repeatable.
          - Create a Horizontal Scrollbar component and add it to the datalist component (timeilne)
                - If you have the Horizontal scrollbar designed, then select it and convert it to a Horizontal Scroll component (using the HUD - the black overlay that comes up when you select a graphic element)
                - After conversion you would need to define the parts of the H. Scrollbar (Track, thumb, right button, left button). Note: It helps if you designed your H. Scrollbar with these components in AI/PSD.
          - Now come back to the artboard, and select the H. Scrollbar by clicking on it.
          - Cut the H. Scrollbar
          - Click the Datalist element, and go to Edit Parts (in HUD)
          - Paste the H . Scrollbar inside the Datalist element. This will attach the scrollbar to the data.
          Hope this helps,
          Fu
