0 Replies Latest reply on Oct 15, 2009 8:44 AM by jhndnn
    Command line build and source control (svn)
      Using Flash Builder, what should be checked into source control to enable a command line build without any user interaction? Just checking in all the source directories is apparently not enough - as far as I can tell the individual projects have to be added to the workspace for the build to work.
      I've experimentally determined that .metadata/.plugins/com.abobe.flexbuiler.project and .metadata/.plugins/org.eclipse.core.resources are the 2 directories required for my build to work. the com.adobe.flexbuilder.project directory is pretty straight forward and it's obvious what needs to get checked in. the org.eclipse.core.resources directory has quite a bit more files contained in it - do all of these need to be checked into source control for the build to work? Deleting the .history folder appears to be ok.
