1 Reply Latest reply on Oct 25, 2009 1:49 AM by merobertsjr
    Tab key issues
    nickynack
      Hi there,
      i'm using captivate 4 and the project involves the learner to fill in text boxes on a particular slide, the problem is that i can't get the tab key to move the cursor between text boxes when viewing the project. Any ideas?
      Cheers
        • 1. Re: Tab key issues
          merobertsjr Level 2
          You could set the tab key as a short cut key.  Typically it is set to Enter. Try editing the properties of the text entry box, then set shortcut key.  Towards the bottom click on select keys and change the current shortcut key to tab.  Hope that helps...
