8 Replies Latest reply on Oct 16, 2009 6:51 AM by kglad
    how to correctly rotate a wheel menu
    fabec
      hi,
      i have a ring shaped menu with 7 entries on it (see attached image).  when the mous is over it it rotates depending on mouse position.  and when 1 entry is seleceted, i want it to rotate back to a certain angle so that such selection appears on top of it (12:00 .on a clock).   i have an array with the corresponding rotations for each entry.  but i would like it to rotate through the shortest way and i simply can't find it!.  logic says: if destinationAngle>currentAngle rotate+, but this doesn't care for the 180/-180 passage.  any ideas?  thank you in advance,  fabec.
        • 1. Re: how to correctly rotate a wheel menu
          instead of dealing with angles from -180 to +180, convert all angles to 0 to 360 by using:
          ang = (ang+360)%360;
          • 2. Re: how to correctly rotate a wheel menu
            fabec Level 1
            sorry i pressed the wrong button...
            hi,
            thanks, kglad, again, for your answer.  i've tried the modulo option (which i saw in one of your answers to someone else on this forum) but it isn't enough (though it helps) to solve my case.
            what i am looking for is the shortest way to rotate my wheel, not to rotate it at once, and the problem is that the reference angle changes permanently:  let's say the angle of the item i clicked is 250 (or -110 before % operation).  when i trigger the rotation process (+/- 1 pix/fram @25fps) my wheel is at 0 degrees.  allthough 250 is bigger than 0 my rotation has to be negative.  but if the angle i am looking for is 110, still bigger than 0, my rotation has to be positive.  basicaly, if i don't do the modulo operation, it works for certain angles, and for others if i apply it...  what i need to find is...  the shortest way.
            thanks, fabec
            • 3. Re: how to correctly rotate a wheel menu
              for angles less than 180, rotate to 0.  for angles greater than 180, rotate to 360.
              in your example, rotate from 250 up to 360.
              • 4. Re: how to correctly rotate a wheel menu
                fabec Level 1
                it was actually the other way round: going from 0 to 250, not 250 to 0...
                but, never mind here is the code concerned, hope it will helps.  sorry i just don't know how to format it properly in this forum:
                // if the distance between the wheel and the mouse is under 190, the wheel rotates with mouse position
                if (distance<190) {
                     rotatingClip._rotation -= (rotatingClip._parent._xmouse-rotatingClipCenterX)/100;
                     midO = false;
                } else {
                     var wheelCurrentRotation:Number = rotatingClip._rotation;
                     var targetRotation:Number = arrayWithTargetRotations[menuItemSelected];
                     var wheelCurrentRotationModulo:Number = (wheelCurrentRotation+360)%360;
                     var targetRotationModulo:Number = (targetRotation+360)%360;
                     switch (true) {
                          // if current rotation is within 20 degrees of the target, the target rotation is appplied and rotation stopped
                          case (wheelCurrentRotationModulo+10>=targetRotation && wheelCurrentRotationModulo-10<=targetRotation) :
                               rotatingClip._rotation = targetRotation;
                               midO = true;
                               break;
                          //THIS IS THE PART WHERE I HAVE THE PROBLEM:  WHAT IS THE SHORTTEST WAY FROM MY CURRENT POSITION TO MY TARGET
                          //WHAT DIRECTION TO SPIN??
                          case (targetRotation-wheelCurrentRotationModulo<180 && midO == false) :
                               rotatingClip._rotation -= incr/2;
                               break;
                          case (targetRotation-wheelCurrentRotationModulo>180 && midO == false) :
                               rotatingClip._rotation += incr/2;
                               break;
                mid = false;
                • 5. Re: how to correctly rotate a wheel menu
                  fabec Level 1
                  double post...
                  Message was edited by: fabec
                  • 6. Re: how to correctly rotate a wheel menu
                    that should be:  (180+bar._rotation)%360;
                    so, for example, rotateF() will cause bar towards rotate north:
                    bar.onEnterFrame=function(){
                        this._rotation+=inc;
                    function rotateF(){
                        var r:Number = (180+bar._rotation)%360;
                        if(r<180){
                            inc=-3;
                        } else {
                            inc = 3;
                    • 7. Re: how to correctly rotate a wheel menu
                      fabec Level 1
                      hi kglad,
                      it worked!  i just had to do a little tweening: it is on the difference between present angle and destination angle that i applied your magic modulo operator, and the 'if' on your function now checks for a difference between 0 and 180, for positive rotation, or 181 and over or negative, for negative rotation:
                      //distance between angles
                      var r:Number = (180+(presentRotation-targetRotation))%360.
                      //positive or negative rotation..  ('incr' is defined elsewhere...)
                                     case (r<=180 && r>=0 && midO == false) :
                                          menuSP._rotation += incr/2;
                                          break;
                                     case ((r>180 || r<0) && midO == false) :
                                          menuSP._rotation -= incr/2;
                                          break;
                      anyway, your idea was the correct one.  it is allways a warm pleasure to find a helping mind with time to spare on the other side of the wire.  thank you very much,  fabec
                      • 8. Re: how to correctly rotate a wheel menu
                        you're welcome.
