1 Reply Latest reply on Aug 4, 2008 2:23 PM by RoboWizard
    Replace image but keep hotspots
    CharlieG18
      I think I know the answer but I'll ask because if I'm wrong in will save a huge amount of work. Here goes - Is it possible to replace the underlying image while retaining the previous defined hotspots? I have some new screens that are mostly the same as the old ones so keeping the old hotspots would save me a lot of work.
        • 1. Re: Replace image but keep hotspots
          RoboWizard Level 4
          Welcome to our community, Charlie
          All you really should have to do is to save the new image to the same location on your hard drive using the same name as was used before. The image should update and the image map regions should remain intact.
          Note that if the image dimensions changed, you will need to right-click the image and choose Reset Size. But that shouldn't affect your image map regions.
          Cheers... Rick
