0 Replies Latest reply on Oct 15, 2009 7:54 PM by bshan-yu
    can't set public Object in HTTPService result listener
    bshan-yu
      Hello.
      I am using a data object class.  The class is based on a class that contains the HTTPService calls.  I want to return the event.results to the local instance of the class by setting a public Object = the results Object. However, the public object is null after the HTTPService event result listener function is finished.
      It is easier to see than to describe:
      In the main application. i make an instace of my activity class:
      myactivity:activity = new activity() ;
      now, I invoke the getdata method:
      myactivity.getdata() ;
      The getdata() method fails at runtime, because it tries to reference the results object.
      See the base class and the activity class below.
      BASECLASS: (just the main parts are listed here):
      public class transferObject
              public var baseurl:String ;
              public var dbresult:Object =new Object();
              public var service:HTTPService ;
              public function transferObject()
              geturl("ghost") ;
              public function geturl(db:String) : void
                      baseurl = "https://xyzzy/" ;
              public function getHttpService(methodname:String):void {
                      service = new HTTPService();
                      service.url = this.baseurl + methodname;
                      service.channelSet ;
                      service.method = "POST";
                      service.addEventListener("result", httpResult );
                      service.addEventListener("fault", httpFault);
                      service.send();
                 public function httpResult(event:ResultEvent):void {
                      dbresult = event.result ;
      //DBRESULT IS THE OBJECT I WANT TO REFERENCE IN THE DERIVED CLASS
                   //Do something with the result.
                  public function httpFault(event:FaultEvent):void {
                      var faultstring:String = event.fault.faultString;
                      Alert.show('Error sending data: '+faultstring+' '+event.fault);
      HERE IS THE DERIVED CLASS:
      package dataObjects
          public class activity extends transferObject
          import mx.controls.Alert ;
      [Bindable]
      public var event_id:String ;
      [Bindable]
      public var description:String ;
             public function activity()
                  super();
              public function getdata():void
                  getHttpService("eventually.sendtest") ;
                this.event_id = dbresult.result.activities.activity.getItemAt(0).event_id ;
      ----> THE LINE ABOVE FAILS AT RUN TIME BECAUSE THE DBRESULT OBJECT IS NULL
      THANK YOU FOR ANYHELP YOU CAN PROVIDE
