4 Replies Latest reply on Oct 19, 2009 8:31 AM by msakrejda
    Number formatting not working.
    flexprad09 Level 2
      Hello All,
      I want to format particular column's value in DataGrid's Dataprovider to change there decimalseparator from "." to "."
      I have tried the code written below but is not working.
      values are still coming same.
      var nf:NumberBase = new NumberBase();
      nf.decimalSeparatorFrom = ".";nf.decimalSeparatorTo = ",";
      var myDG:DataGrid  // this is my Datagrid and is already populated
      var araycoll:ArrayCollection = ArrayCollection(myDG.dataProvider);  //my Datagrid's DP.
      trace(nf);
      var DGColumn:DGColumns;  //DGColumns is custom Class and contains info like column's name, type etc.
      for(var i:int=0;i<araycoll.length;i++)
           for each(DGColumn in myDataSource.columnArray)        //looping through column array just to find if type is numeric.
               if(DGColumn.columnType== "Numeric")
               nf.formatDecimal(String(araycoll[i][DGColumn.columnName])); //araycoll[i][DGColumn.columnName] is containing DG's cell value and is coming alrite
               trace(araycoll[i][DGColumn.columnName]);
      myDG.dataProvider = araycoll;
      i have also tried nf.format() with NumberFormatter type.
      when i debug into ListCollectionView i see that its flooring the number.
      Any help or links on how to do it are appreciated.
      Or if there's any other shorter way to do this.
      Thanks a lot,
      PRad.
