3 Replies Latest reply on Oct 16, 2009 9:05 AM by Powder77
    Casting a ValueObject
    Powder77
      Hi Guys
      I am fairly new to flex and a little there is the code that is confussing me:
         xmlns:mx="library://ns.adobe.com/flex/halo" minWidth="1024" minHeight="768" xmlns:subscription="services.subscription.*" xmlns:ganalytics="services.ganalytics.*" creationComplete="application_creationCompleteHandler(event)">
      <fx:Script>
      <![CDATA[
      import mx.events.FlexEvent;
      import mx.controls.Alert;
      import valueObjects.DashStatsVO;
      public var myDash:DashStatsVO = new DashStatsVO();
      protected function application_creationCompleteHandler(event:FlexEvent):void
      getDashStatsResult.token = ganalytics.getDashStats();
      myDash = getDashStatsResult.lastResult as DashStatsVO;
      </fx:Script>
      <fx:Declarations>
      <s:CallResponder id="getDashStatsResult"/>
      <ganalytics:Ganalytics id="ganalytics" fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)" showBusyCursor="true"/>
      <!-- Place non-visual elements (e.g., services, value objects) here -->
      </fx:Declarations>
      </s:Application>
      When I do this getDashStatsResult.lastResult. I get the auto complete list of the objects properties which is what I'd expect, but if I try and do myDash. I don't see a list of the objects properties just the standard "hasOwnProperty" etc.
      All I want to do is save time typing I don't want to have to do getDashStatsResult.lastResult.property all the time but instead do myDash.property.
      Am sure I am making a silly mistake but any help would be much appreciated .
      Regards
      Chris
        • 1. Re: Casting a ValueObject
          David_F57 Level 5
          Not sure if I am reading this right but I assume by property you mean the fieldname of the retreived data so then to get a value it would be
          myDash[x].myproperty.
          i'm either right or so far off its not funny
          David.
          • 2. Re: Casting a ValueObject
            mewk Level 3
            You are assuming .lastResult is populated immediately. It is not; you need to give your service/responding objects time to call and then retrieve data from the server.
            try this:
            <script>
                 protected function application_creationCompleteHandler(event:FlexEvent):void {
                 protected function resultHandler(): void {
            </script>
            <declarations>
                 <s:CallResponder id="getDashStatsResult" result="resultHandler()"/>
            </declaration>
            • 3. Re: Casting a ValueObject
              Powder77 Level 1
              Thanks everyone for all your help. I knew the result was not populated immediately, but I assumed that flash builder would still show the object properties. Typing it in the result handler works like a treat.
