4 Replies Latest reply on Oct 16, 2009 10:38 AM by zjimbo
    How to export files in CS4 to a new project?
    zjimbo Level 1
      I am trying to create a "Master" project by exporting or combining 3 of my edited projects into a distinctive project.
      I have tried creating a New Project, as well as opening the first project of the Master series and trying to export the other 2 files into it.
      With CS3 all I did was double click in the project box and import.
      In CS4 it says the export files are not responding.
      I can export single clips but not a complete project file.
      It was so simple in CS3, but now it does not work in CS4; what's up.
      Thanks Jim
        • 1. Re: How to export files in CS4 to a new project?
          zjimbo Level 1
          Appologies: I mean to say "Import".
          • 2. Re: How to export files in CS4 to a new project?
            zjimbo Level 1
            One thing I found ont. Not sure if it matters, but I noticed me Encoded Files folders were empty.
            All the other files Auto Save, Media Cashe ect. are full.
            • 3. Re: How to export files in CS4 to a new project?
              Jim_Simon Level 8
              Walk me through this.
              You create a new Master project.  You right click in the Project pane and select Import...  You navigate to Project A and click on that Premiere Project file.  What exactly happens next?
              • 4. Re: How to export files in CS4 to a new project?
                zjimbo Level 1
                Thanks for all the input.......I got it fixed; I think.
                I reloaded CS4. And this time when I got to the "Import not responding" I clicked "Allow it to respond" or something like that. I had done that before but all I got was a clip or clips, not the projects. But this time it worked, I got the whole project.
                I had to double click the grayed file in sequence #1.
                t then went to a new TL still called seq #1.
                Then I went back to the origional TL and deleated the grayed area.
                Then I went back to second TL: "Edit" / "Select all" / "Edit" / "Copy".
                Then back to the origional Seq #1 or TL: "Edit" / "Paste" / "Save".
                Then I went up to the sceond TL header box and the clicked the "X - Close".
                I ended up with new project with all three projects. I changed the name to Master #2.
                After that I Rendered. I am still waiting on it to render for an 1 1/2 hours. Then I can see exactly where I am. But at least I get this far.
                Thanks JIM
