2 Replies Latest reply on Oct 20, 2009 7:41 AM by naramski
    LiveCycle broken by UserManagerService
    david657 Level 1
      We have a problem with a service using the activity "Find Group" in Livecycle ES.
      In DEV, everything was ok, but when we switch to production, we have this exception :
      Caused by: | [com.adobe.livecycle.usermanager.client.DirectoryManagerServiceClient] errorCode:16385 errorCodeHEX:0x4001 message:Exception wrapped in DSCException is Null or NOT An Instance of UMException chainedException:ALC-DSC-023-000: com.adobe.idp.dsc.registry.service.NoActiveServiceConfigurationException: There is no active service configuration for service: DirectoryManagerServicechainedExceptionMessage:There is no active service configuration for service: DirectoryManagerService chainedException trace:ALC-DSC-023-000: com.adobe.idp.dsc.registry.service.NoActiveServiceConfigurationException: There is no active service configuration for service: DirectoryManagerService
      I have tried a new service that only do one lookup. In DEV, envything is ok, but after deployement in PROD we have the exception (bellow). The two environnment have the same Domains configuration. We migrate the service by using the "create archive"/"import archive" from Livecycle Workbench/Livecycle Admin.
      When we go the administrative console " Services/Applications & Services/Service Management / Config DirectoryManagerService" we also have the message : There is no active service configuration for service: DirectoryManagerService.
      Our installation is inusable, we cannot use the DirectoryManagerService anymore and it seem there is no mean to "reset" the service. Our process rely on this component.
      I think the DirectoryManagerService from UserManagerService is broken. I wonder if there is a solution other than delete all the data and reinstall LiveCycle ES ?
      Thanks for your help
      David NARAMSKI
      ALC-DSC-003-000: com.adobe.idp.dsc.DSCInvocationException: Invocation error.
      at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.jav a:152)
      at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor. java:140)
      at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptor ChainImpl.java:60)
      at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(Transa ctionInterceptor.java:74)
      at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.execute(EjbTr ansactionCMTAdapterBean.java:342)
      at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doSupports(Ej bTransactionCMTAdapterBean.java:212)
      at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EJSLocalStatelessEjbTransactionCMTAdapter_ caf58c4f.doSupports(Unknown Source)
      at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:104)
      at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.intercept(TransactionInt erceptor.java:72)
      at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.intercept(InvocationStra tegyInterceptor.java:55)
      at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(InvalidStateIntercep tor.java:37)
      at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterc eptor.java:132)
      at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterceptor.java:48)
      at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineImpl.java:115)
      at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:118)
      at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.routeMessage(AbstractMessage Receiver.java:91)
      at com.adobe.idp.dsc.provider.impl.vm.VMMessageDispatcher.doSend(VMMessageDispatcher.java:21 5)
      at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispat cher.java:57)
      at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
      at com.adobe.workflow.engine.PEUtil.invokeAction(PEUtil.java:724)
      at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.transientInvoke(WorkflowDSCInvoker. java:346)
      at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.invoke(WorkflowDSCInvoker.java:157)
      at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doRequiresNew (EjbTransactionCMTAdapterBean.java:284)
      at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EJSLocalStatelessEjbTransactionCMTAdapter_ caf58c4f.doRequiresNew(Unknown Source)
      at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:143)
      at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.invoke(AbstractMessageReceiv er.java:315)
      at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapSdkEndpoint.invokeCall(SoapSdkEndpoint. java:138)
      at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapSdkEndpoint.invoke(SoapSdkEndpoint.java :81)
      at sun.reflect.GeneratedMethodAccessor356.invoke(Unknown Source)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
      at java.lang.reflect.Method.invoke(Method.java:585)
      at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
      at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
      at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
      at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
      at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
      at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
      at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
      at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
      at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
      at javax.servlet.http.HttpServlet.service(HttpServlet.java:763)
      at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
      at javax.servlet.http.HttpServlet.service(HttpServlet.java:856)
      at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper.java:1096)
      at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper.java:1037)
      at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:145)
      at com.adobe.idp.dsc.provider.impl.soap.axis.InvocationFilter.doFilter(InvocationFilter.java :43)
      at com.ibm.ws.webcontainer.filter.FilterInstanceWrapper.doFilter(FilterInstanceWrapper.java: 190)
      at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:130)
      at com.ibm.ws.webcontainer.filter.WebAppFilterChain._doFilter(WebAppFilterChain.java:87)
      at com.ibm.ws.webcontainer.filter.WebAppFilterManager.doFilter(WebAppFilterManager.java:832)
      at com.ibm.ws.webcontainer.filter.WebAppFilterManager.doFilter(WebAppFilterManager.java:679)
      at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:566)
      at com.ibm.ws.wswebcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:478)
      at com.ibm.ws.webcontainer.servlet.CacheServletWrapper.handleRequest(CacheServletWrapper.jav a:90)
      at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContainer.java:748)
      at com.ibm.ws.wswebcontainer.WebContainer.handleRequest(WebContainer.java:1466)
      at com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChannelLink.java:119)
      at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleDiscrimination(HttpInboundLink .java:458)
      at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleNewInformation(HttpInboundLink .java:387)
      at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.ready(HttpInboundLink.java:267)
      at com.ibm.ws.tcp.channel.impl.NewConnectionInitialReadCallback.sendToDiscriminators(NewConn ectionInitialReadCallback.java:214)
      at com.ibm.ws.tcp.channel.impl.NewConnectionInitialReadCallback.complete(NewConnectionInitia lReadCallback.java:113)
      at com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.futureCompleted(AioReadCompletionLi stener.java:165)
      at com.ibm.io.async.AbstractAsyncFuture.invokeCallback(AbstractAsyncFuture.java:217)
      at com.ibm.io.async.AsyncChannelFuture.fireCompletionActions(AsyncChannelFuture.java:161)
      at com.ibm.io.async.AsyncFuture.completed(AsyncFuture.java:136)
      at com.ibm.io.async.ResultHandler.complete(ResultHandler.java:195)
      at com.ibm.io.async.ResultHandler.runEventProcessingLoop(ResultHandler.java:743)
      at com.ibm.io.async.ResultHandler$2.run(ResultHandler.java:873)
      at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1473)
      at com.adobe.idp.dsc.registry.service.impl.ServiceRegistryImpl.getHeadActiveConfiguration(Se rviceRegistryImpl.java:944)
      at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.resolveConfiguration(ServiceEngineImpl.ja va:148)
      at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:73)
      at com.adobe.livecycle.usermanager.client.DirectoryManagerServiceClient.findPrincipals(Direc toryManagerServiceClient.java:845)
      at com.adobe.idp.dsc.um.lookup.UserManagerLookupServiceImpl.findGroup(UserManagerLookupServi ceImpl.java:150)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
      at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.jav a:118)
      at com.adobe.livecycle.usermanager.client.ManagerServiceClient.throwNonUMExceptionAsUMExcept ion(ManagerServiceClient.java:53)
      at com.adobe.livecycle.usermanager.client.ManagerServiceClient.handleException(ManagerServic eClient.java:90)
      at com.adobe.livecycle.usermanager.client.DirectoryManagerServiceClient.findPrincipals(Direc toryManagerServiceClient.java:849)
      ... 91 more
        • 1. Re: LiveCycle broken by UserManagerService
          Steve L Walker Level 5
          I would consider two possibilities:
          1) It is unlikely that your DEV and PROD directories have the same provider URL. If they do you may have more trouble than you know. All user lookup services use a provider URL, either configured directly in each service instance or configured in the base service. Validate the provider URLs.
          2) Your PROD directory service may not enable access from external sources, by default. Check with your security admin. They may have to configure and enable a named user who can access the directory. The user credentials could then be used to run the LiveCycle ES service.
          Steve
          • 2. Re: LiveCycle broken by UserManagerService
            naramski
            How can we have two different provider URL in the DEV and PROD environment ? The two LiveCycle ES server have the LDAP connexion configured the same way.
            It is the same LDAP server, same credentials, ...
            Maybe I don't understand well what is the provider URL ? Can I have the provider URL different if the LDAP are configured the same way ?
            By the way, the user are all defined in LDAP but the Group are created in the "Default Domain". Can it be a problem ?
