1 Reply Latest reply on Oct 16, 2009 11:51 AM by netnerd85
    HTTPService and ArrayCollection issues
    netnerd85 Level 1
      Hey all,
      I have a datagrid display a list of businesses, when you click on a business its details come up then you click "view notes". The notes populate another datagrid, but only if there is two or more notes. It will not display one note, only once there is two.
      The notes.xml.php file works perfectly fine. I dont understand why it wont show one note, only more than one, what on earth could be wrong. I spent over an hour and a half on this code, then I added another record into the DB to find this error. It makes no sense to me, please help!
      Some core code
      [Bindable] private var allContactLogs:ArrayCollection = new ArrayCollection;
      private function initAllContactLogs():void
          currentState = 'viewAllContactLogs';
          allContactLogs = new ArrayCollection;
          gateway.url = 'http://localhost/project/notes.xml.php';
          gateway.request = {"bid":businessDetails.business_id};
          gateway.method = 'get';
          gateway.send();
          gateway.addEventListener(ResultEvent.RESULT, viewAllNotes);
          gateway.addEventListener(FaultEvent.FAULT, faultHandler);
      private function viewAllNotes(e:ResultEvent):void
          allContactLogs = e.result.contact_logs.contact_log;
                      <mx:DataGrid id="contactLogs" dataProvider="{allContactLogs}" change="viewContactLogDetails(event)" left="418" top="40" height="143" width="400">
                          <mx:columns>
                              <mx:DataGridColumn headerText="Date Contacted" dataField="date_contacted"/>
                          </mx:columns>
                      </mx:DataGrid>
        • 1. Re: HTTPService and ArrayCollection issues
          netnerd85 Level 1
          Found out by this post, http://forums.adobe.com/message/2130885 that it is a BUG
          Fixed my code doing the following
          import mx.utils.ArrayUtil;
          import mx.utils.ObjectProxy;
          private function viewAllContactLogs(e:ResultEvent):void
              if(e.result.contact_logs.contact_log is ArrayCollection){
              }else if(e.result.contact_logs.contact_log is ObjectProxy){
                  allContactLogs = new ArrayCollection(ArrayUtil.toArray(e.result.contact_logs.contact_log));
          Maybe it will be fixed one day? Flex is the most annoying thing I have put effort into learning. Not happy jan, not happy at all!
