1 Reply Latest reply on Oct 16, 2009 7:50 PM by Kona Bob
    Remove Wind Noise.
    mishie927
      Hello, I have some clips and in some parts there is some wind noise which quite a hassle lol, is there any way to reduce or move it in PPCS4?
      Thank you!
        • 1. Re: Remove Wind Noise.
          Kona Bob Level 2
          There may be a way to do it it Premiere, but I don't think it will be easy.
          To reduce wind, AC/ Fan noise, an unwelcome telephone ring, etc. I always use the noise reduction process in Adobe Audition. It's easy to use and very effective. It allows you to capture a brief segment of the "noise", then it will filter those frequencies out to the level you select (0-100). This is a key feature, because aggressive filtering will often distort the audio you want to keep- particularly voices. You can adjust to an acceptable balance b/t noise removal and fidelity for the remaining sound.
          Soundbooth may have something similar, but I've never looked at it.
