3 Replies Latest reply on Oct 17, 2009 7:35 PM by S&K Enterprises
    fade in text with layer styles
    S&K Enterprises Level 1
      I'm trying to have the letters in a word slowly fade up. I have the text layer, added a few layer styles (stroke ,bevel, drop shadow) and then applied the animation preset/ text/ animate in/fade up by letter.  However, what fades up are the styles first for each letter. So the first appearance of each letter is the stroke color, and then the other styles are slowly added until each letter is complete.  I want each completed letter to slowly fade up. I couldn't find any parameter of the animator that would accomplish that.  Any ideas?
        • 1. Re: fade in text with layer styles
          Two possibilities: Pre-compose everything and fade the comp or use a second layer that has the layer styles, but in its Blending Options for the layer styles has set Fill opacity to zero, so only the styles are rendered, but not the source. Whjat you are seeing is normal behavior based on how styles are supposed to work. Whenever there is a non-zero (non-transparent) pixel, the get applied, where the pixels opacity acts as amultiplier for the style's intensity. Looks good for some, but often causes this popping appearance...
          Mylenium
          • 2. Re: fade in text with layer styles
            I think that the only thing causing you problems is the stroke. Try adding the stroke using the character palette instead of layer styles. Now if you simply add an opacity animator to the text layer, set the opacity to 0, and animate the Range Selector you should have what you want.
            • 3. Re: fade in text with layer styles
              Thanks Rick. That works. Using the character pallette to add the stroke, however, curiously gives a slightly different look to the letters than when applyng the stroke as a style. But at least the stroke color doesn't fade up first. Thanks again.
