6 Replies Latest reply on Oct 17, 2009 9:37 PM by jay fresno
    Noob question - where to put plug ins on Mac OS
    jay fresno Level 2
      I downloaded the flatten pages javascript from windjack.com. I read the instructions for installing the script, but can't find the correct folder to put it in. According to the JavaScript console, the script should be put into:
      MacBookPro/Applications/Adobe Acrobat 9 Pro/Adobe Acrobat Pro 9.app/Contents/MacOS/JavaScripts
      I can find the Applications/Adobe Acrobat 9 Pro folder, but there's not much of anything inside it. (see screen cap)
      I'd love to use this script, so if anyone can help me I would greatly appreciate it!Picture 1.png
        • 1. Re: Noob question - where to put plug ins on Mac OS
          Have you run the script to locate the path for JavaScirpts in Acrobat's JavaScript console?
          // user JavaScript path
          try {
          var userJS = app.getPath("user","javascript");
          } catch(e) {
          var userJS = "User has not defined any custom JavaScripts";
          console.println('User JavaScirpts: ' + userJS);
          // app JS path
          try {
          var appJS = app.getPath("app","javascript");
          } catch(e) {
          var userJS = "App has not defined any custom JavaScripts";
          console.println('Application JavaScirpts: ' + appJS);
          • 2. Re: Noob question - where to put plug ins on Mac OS
            jay fresno Level 2
            Thank you for responding to my question.
            When I run the script in your message, I get the following:
            appJS is not defined
            1:Console:Exec
            undefined
            I don't know enough about scripts to understand the message.
            The instructions that come with the downloaded plug in say to put the following code into the JavaScript console:
            App.getPath("user",javascrpt");
            When I run the above script, the path shown is:
            /MacBookPro/Application/Adobe Acrobat 9 Pro/Adobe Acrobat Pro 9.app/Contents/MacOS/JavaScripts/
            I can find /MacBookPro/Application/Adobe Acrobat 9 Pro/ but as shown in the screen shot, there is no /Adobe Acrobat Pro 9.app/Contents/MacOS/JavaScripts/ inside of the Adobe Acrobat 9 Pro folder.
            I did a search throughout the computer looking for the JavaScripts folder, and couldn't find it.
            I have no problem using Acrobat 9 Pro, so I assume that there is nothing wrong with the installation of the application itself.
            If you have further suggestions, I'd truly appreciate it.
            • 3. Re: Noob question - where to put plug ins on Mac OS
              Is your system set to allow you see system and hiden files?
              You will be placing code into areas that only adminstrators or system programers work in.
              • 4. Re: Noob question - where to put plug ins on Mac OS
                jay fresno Level 2
                I think I turned on hidden files. I found an article on the web describing how to do that at http://www.macworld.com/article/51830/2006/07/showallfinder.html
                But after following the instructions, I still couldn't see the correct folders.
                A Unix buddy, was able to get the plug in installed finally after typing some stuff into the Terminal on my computer, but I have no idea what the circuitus route was or what he typed in order to find the right folder, and I would not be able to replicate it.
                There must be an easier way to do this - Surely other Mac users didn't have to go thru this to get the flattener installed ! ?
                • 5. Re: Noob question - where to put plug ins on Mac OS
                  MichaelKazlow MVP & Adobe Community Professional
                  The application itself is a package which is really nothing more than a folder. Right-click or control-click on the Acrobat application and use the show package contents item. That will display everything within the application package/folder.
                  • 6. Re: Noob question - where to put plug ins on Mac OS
                    jay fresno Level 2
                    Michael,
                    Thank you so much! This is really a revelation to me. I certainly learned something from you.
