1 Reply Latest reply on Oct 18, 2009 4:28 AM by David_F57
    Best way to "page" through data?
    Handycam Level 1
      If I have a XM, something like
      <people>
      <person>
      <firstname>john</firstname>
      <lastname>smith</lastname>
      </person>
      <person>
      <firstname>robert</firstname>
      <lastname>walker</lastname>
      </person>
      </people>
      And I create some bound fields to display this, what's the best way to "page" the data?
      I know I can create an XML variable of the data and then access person[0].firstname, but I need to have a button or other ui element that would choose person 0,1,2,3 etc.
      Normally I's use a list, but this application calls for a static screen where only the data changes when buttons are chosen.
        • 1. Re: Best way to "page" through data?
          David_F57 Level 5
          I use this method(this is simplified) as it doesn't require any sort of data services, you can have change events etc for editing/deleteing. the slider is just for poc, a prev/next button could just as easily do.
          xmlns:mx="library://ns.adobe.com/flex/halo" minWidth="800" minHeight="400" creationComplete="initApp()" width="800" height="400">
          <fx:Declarations>
          <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
          <fx:Script>
          <![CDATA[
          import mx.collections.ArrayCollection;
          [Bindable] private var Arr:ArrayCollection=new ArrayCollection();
          private var Sel:int = 0;
          protected function initApp(): void
          Arr.addItem({id:1,name:"John",surname:"Robertson",age:30});
          Arr.addItem({id:2,name:"Peter",surname:"Williams",age:35});
          Arr.addItem({id:3,name:"Jane",surname:"Brown",age:23});
          Arr.addItem({id:4,name:"Rebecca",surname:"Smith",age:42});
          Arr.addItem({id:5,name:"Susan",surname:"Reynolds",age:25});
          Arr.addItem({id:6,name:"Michael",surname:"Royce",age:23});
          Arr.addItem({id:7,name:"Jack",surname:"Jones",age:22});
          Arr.addItem({id:8,name:"Pete",surname:"Young",age:50});
          Arr.addItem({id:9,name:"Robert",surname:"Peters",age:39});
          hs.maximum = Arr.length-1;
          hs.value = 0;
          updateList();
          protected function updateList():void
          Sel = hs.value;
          surname.text= Arr[Sel].surname;
          firstname.text= Arr[Sel].name;
          age.text= Arr[Sel].age;
          </fx:Script>
          <s:Group width="497" height="114" horizontalCenter="0" verticalCenter="0">
          <s:TextInput id="surname" x="46" y="45"/>
          <s:TextInput id="firstname" x="182" y="45"/>
          <s:TextInput id="age" x="318" y="45"/>
          <s:HSlider id="hs" x="62" y="96" width="200" minimum="0" maximum="1" liveDragging="true" change="updateList()" value="-1"/>
            </s:Group>
          </s:Application>
          David
