1 Reply Latest reply on Oct 18, 2009 7:42 PM by eartha55
    can't get transitions to execute
    eartha55
      Hi folks,
      I'm building my first Flex app, which is a typical simple quiz. Intro state, string of questions, then a result.
      I'm stuck right now in that my transitions are not running. I suspect it has something to do with the fact that I extended the Application class and typed my main application mxml file to that class so that I could keep Actionscript separate from MXML in two separate files. The app will switch states successfully but it won't run the transition effects on a state change, and so my endEffect event is not firing...
      It may be that I have something else wrong altogether.
      Here is the application MXML file:
      <classes:QuizApplication
          xmlns:local="*"
          xmlns:mx="http://www.adobe.com/2006/mxml"
          xmlns:classes="classes.*"
          layout="absolute"
          currentState="landingState"
          <mx:HTTPService id="questions" url="./data/questions.xml" />
          <classes:states>
              <mx:State name="landingState"/>
              <mx:State name="landingStateOut" basedOn="landingState"/>
              <mx:State name="question">
                  <mx:RemoveChild target="{text1}"/>
                  <mx:RemoveChild target="{startButton}"/>
                  <mx:AddChild relativeTo="{vbox1}" position="lastChild">
                      <local:FormHolderVBox id="formHolder" applicationVO="{applicationVO}" width="348" height="248" />
                  </mx:AddChild>
              </mx:State>
              <mx:State name="resultState"/>
              <mx:State name="betweenQuestions1" basedOn="question">
                  <mx:RemoveChild target="{formHolder}"/>
                  <mx:RemoveChild target="{vbox1}"/>
              </mx:State>
          </classes:states>
          <classes:transitions>
              <mx:Transition id="advanceTransition0" fromState="landingState" toState="landingStateOut">
                  <mx:Fade
                      duration="2000"
                      id="fadeToBetween"
                      alphaFrom="1"
                      alphaTo="0"
                      effectEnd="continueAdvance();"
              </mx:Transition>
              <mx:Transition id="advanceTransition1" fromState="question" toState="betweenQuestions" effect="{fadeToBetween}" />
              <mx:Transition id="advanceTransition2" fromState="question" toState="betweenQuestions">
                  <mx:Fade
                      id="fadeToQuestion"
                      alphaFrom="0"
                      alphaTo="1"
              </mx:Transition>
          </classes:transitions>
          <mx:Canvas x="45" y="41" width="392" height="361" id="canvas">
              <mx:VBox x="21" y="47" height="291" width="348" id="vbox1">
                  <mx:Text text="Take this quick quiz to find out what type of shopper you are!" width="347" height="40" fontSize="12" id="text1"/>
                  <mx:Button label="Start the Quiz" id="startButton"/>
              </mx:VBox>
          </mx:Canvas>
          <mx:Text text="What kind of shopper are you?"  fontSize="21" fontWeight="bold" fontFamily="Arial" x="45" y="41"/>
      </classes:QuizApplication>
      And here is the associated Actionscript:
      package classes
      import classes.events.AdvanceEvent;
      import flash.events.MouseEvent;
      import mx.collections.ArrayCollection;
      import mx.containers.Canvas;
      import mx.controls.Button;
      import mx.core.Application;
      import mx.events.FlexEvent;
      import mx.events.EffectEvent;
      import mx.rpc.events.ResultEvent;
      import mx.rpc.http.mxml.HTTPService;
          public class
      QuizApplication extends Application
      Bindable]
              public var
      startButton:Button;
              public var
      canvas:Canvas;
              public var
      questions:HTTPService;
      //[Bindable] ?
      public var questionVOs:ArrayCollection;
      Bindable]
              public var
      applicationVO:ApplicationVO;
      //CONSTRUCTOR
      public function QuizApplication()
      super();
      this.addEventListener(FlexEvent.APPLICATION_COMPLETE, init);
      // go ahead and create singleton of DataClass to store globals
      applicationVO = new ApplicationVO();
      //METHODS
      private function init(e:FlexEvent):void
      startButton.addEventListener(MouseEvent.MOUSE_UP, handleStartQuiz);
      questions.addEventListener(ResultEvent.RESULT, handleQuestionData);
      questions.send();
      // set up listeners for app business
      canvas.addEventListener(AdvanceEvent.FORWARD, advanceToQuestion);
      //canvas.addEventListener(AdvanceEvent.BACKWARD, advanceToQuestion);
              //    canvas.addEventListener(AdvanceEvent.CONTINUE, continueAdvance);
                  // set to start with question 1
      applicationVO.currentQuestion = 0;
      // EVENT HANDLERS
      private function handleStartQuiz(e:MouseEvent): void
      //currentState = "question"; // states hard-coded in mxml
      trace("should set state to landingStateOut");
      trace("currentState now is "+currentState);
      currentState = "landingStateOut";
              private function
      handleQuestionData(e:ResultEvent): void
      applicationVO.questionVOs = new ArrayCollection();
      // loop through XML's ArrayCollections and create an ArrayCollection of QuestionVO's, one for each question in XML
      for each (var question:Object in e.result.questions.question)
                      var
      newVO:QuestionVO = new QuestionVO();
      newVO.questionID = question.id;
      //    trace("question.id is "+question.id);
      newVO.questionText = question.text;
      //    trace("question.text is "+question.text);
      newVO.answers = new ArrayCollection();
                      for
      each (var answer:Object in question.answers.answer)
      newVO.answers.addItem(answer);
      //    trace("answer is "+answer);
      applicationVO.questionVOs.addItem(newVO);
              private function
      advanceToQuestion(e:AdvanceEvent):void
      trace("should transition to next question now");
      e.stopImmediatePropagation();
                  if (
      e.type == "forward")
      //somehow call the transition AdvanceTransition
      applicationVO.currentQuestion++;
      currentState = "betweenQuestions1";
                  else
      applicationVO.currentQuestion--;
              public function
      continueAdvance():void
      trace("should transition now from betweenQuestions2 to question state");
      Can anyone point out what I've got wrong that could cause the Transitions not to work? I thought they were simply supposed to execute on a state change from A to B, for which you've indicated set up a Transition from state A to B.
      Many thanks!
